E boost 2 problem STS
Old Oct 17, 2005 | 09:22 AM
Blackbird's Avatar
ohhhhhhh man I am reading the manual again...
The boost set point values can be set from 0-99 and is NOT directly related to
an actual boost pressure. Boost pressure is set by increasing or decreasing the value of each of the three boost set points.
USER ERROR!!!!!
Dohhhhhhhhhhhhh!
Old Oct 17, 2005 | 08:28 PM
ozzykicks2002's Avatar
So with my sts kit what should I set the controller to for my low boost setting? like for 5# boost what should my settings be?
Old Oct 17, 2005 | 08:32 PM
cablebandit's Avatar
i got mine around 23 setting i think for 15.5 psi of boost.
Old Oct 17, 2005 | 08:33 PM
Blackbird's Avatar
well your wastegate spring is 5lbs, assuming it's the stock wastegate they usually ship.
so set everything to 0 on the eboost and all you should see if 5psi.
or simply turn it off if there is an on/off switch
