Remote oil tank for remote mount turbo?
Charlie
So I guess there really wouldnt be any issues with it.
Finding a oil compatible, high temp, high pressure, continuous duty pump that can supply between 5 and 10 gpm at 60+ psi is gonna be an expensive task.
My voice of reason! I should have remembered it takes the pressure going to the turbo to require the scavenge to get it out. Guess no cookies for me tonight! Damn it. Back to drawing board.
The bearing is actually a thin film of oil, so the shaft floats on the oil within the journal.
you CAN'T suck the oil through and expect sufficient oil supply. It takes VERY little time for a turbo to chew the bearing out when you don't have sufficient oil supply.
If you want a seperate system, you MUST have a high pressure pump to feed to the turbo. No if's and's or but's about it.
Carry on
Oh yeah, did i mention the shaft speeds can reach 90,000+ RPM if you're really working a turbo. Oil is very important
If it where me (but I’m a supercharger guy), I would add turbo discharge restriction. This will create backpressure in bearings (a good thing) and allow turbos to act like they where hooked up to engine oil feed. Also if you have an isolated self contained oil system you can choose a more turbo friendly oil viscosity. It’s not that hard, but designing a system that is robust can be a challenge and expensive.
Mike
The oil comes out everywhere but the drain.
There's a reason turbos are FED with high pressure oil and the drains are made as free flowing and straight down as possible.
Just make sure you have plenty of oil supply, and let the CHRA/bearing limit the flow. Otherwise, don't cry when the bearings, shaft, wheels and housings are all trash.
I think older turbo bearing cartridges may make this pronounced, but if so I still think a isolated oil system can be made to work well.
Mike
Carry on
Pump $200.00
cooler $180.00
custom oil res $150.00
speed control $75.00
mics $100.00
total $705.00 ouch never realized how much I spent!!!!!
