Finally went to the strip, 15 psi on pump!
I wish I would have had time to tune. I was at 11.5:1 afr and 15.5 degrees of timing. I CANNOT GET MY TIMING TO STAY AT TABLE VALUE's!! I am commanding 18 degrees and only getting 15.5???? Anyone know what the deal is?
All in all, not bad for a pumpgas car with a raceweight of about 3840 lbs.
Any videos of the Chevelle running around on the strip or street?
Keep tuning in the off season and set her on kill when the strips open up again.
J
My biggest problem is my converter. I need to buy a different one. I am pushing through mine. I get 5500 rpm off the trans brake! And mmy data log shows the car stayed at 6600 rpm the entire pass and went through the traps at 6900 rpm at 137!! I have a 3.42 gear with a 26" tall tire! That doesn't sound right does it!
That's why I am blowing through it soo bad. Good to know I have more in it. I should have no problem hitting a good 145 mph on pump gas without meth or nitrous or anything.
Turbos are the best power adders! Period!
Even if the my car only sees 140 mph on pump, that is a safe reliable 140 mph on pumpgas. I would be very happy with that. I am running low boost, low timing and a safe AFR.
Untill I get the converter fixed, I am not doing anything else.
