Exhaust gone boost controller dont work, lot of psi!
Old Nov 2, 2002 | 09:50 AM
smokinHawk's Avatar
Default Exhaust gone boost controller dont work, lot of psi!
Well i was having my cutout moved right after my down pipe to see if i could pick up some more power. Well come to pick it up and the shop just got the exhaust cut off, it was near closing time so i said screw it just leave the exhaust off cause i need my car ill brind it back. so it just dumps the exhasut right after the downpipe.
Well on th way home i give it a WOT run and am watching my boost gauge and OH MY it doesnt stop at 10psi it makes it to 12-13psi and im lettiing off, if i hold it down it will keep on going. I havent messed with the MBC were it was at 10psi. I gues this is the same problem were running with the cutout closed through exhaust it only make 7psi. Im going to install my new MBC i got from ss00blue and see if it will stop the boost from going all over the place. ANy one know why that it would do it?
Got to go racing sat night and sunday morning <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Nov 2, 2002 | 10:10 AM
RICE ETR's Avatar
Turbo Addict
Default Re: Exhaust gone boost controller dont work, lot of psi!
less backpressure will make more boost and help spool up times.... i say let her eat <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Nov 2, 2002 | 10:32 AM
SS00Blue's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MOUSETRAP:
<strong>less backpressure will make more boost and help spool up times.... i say let her eat <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It's called boost creep. When the exhaust finds it easier to flow through the turbine and out the stub pipe, than it does to jam through the wastegate tube (being of smaller diameter). Talon guys see this when they put a 3" downpipe and exhaust on a stock turbo. It used to be blamed on the internal w/g, but DSM-Performance proved THAT was wrong.
The BC may help, but the exhaust is going to travel the path of least resistance. Turbines love free-flowing exhausts.
E-mail me. I'll give you my number.
SC
Old Nov 2, 2002 | 11:17 AM
MIGHTYMOUSE's Avatar
just for good measure, make sure they didn't f up any of your boost lines to the wastegate or get any weld spatter up into the wastegate to cause it to malfunction..
i used a mbc and with it straight off the cat pipe i only gained maybe 1.5psi.
Old Nov 3, 2002 | 10:01 AM
cablebandit's Avatar
I never had that problem. I could dial in a consistent 10-15 psi. You get the 1-2 psi spike but it should be fine once you get the controller adjusted. Also.....with open exhaust, the car went to the rich side....you'll need to lean it out some to get back to your target a/f
Old Nov 4, 2002 | 12:43 AM
Carlitos's Avatar
Are all boost controllers electronic? If so, you might also wanna make sure whoever is doing the welding disconnects your battery. I've heard of certain kinds of welders that can short out your electronics. Just a thought.
'Los
Old Nov 4, 2002 | 05:49 AM
smokinHawk's Avatar
Well no adjusting could get ride of my spike.
i installed the ball&check valve boost controller but that didnt do it. i think it has to do with the deltagate wastgate. I need to get a better waste gate.
I ended up setting it to about 8psi so it only spikes to 11psi. Still only gettilng .97* knock.
Got to do somthing with my exhaust beign so short right now as it dumps into the atmosphere right after the downpipe.
Old Nov 4, 2002 | 11:01 AM
SS00Blue's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by smokinHawk:
<strong>Well no adjusting could get ride of my spike.
Got to do somthing with my exhaust beign so short right now as it dumps into the atmosphere right after the downpipe.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Boost Creep. Nothing helps, except use your exhaust, or substantially enlarge the wategate and dumptube/mergepipe.
SC-
E-mail me, and I'll explain more, if needed.
Old Nov 4, 2002 | 11:20 AM
JimmyKash's Avatar
what kinda turbo car r u?
twin or single?
what are the sizes of the turbos/turbo?
how much horsepower are you running?
Please answer these questions and i can help you out
Old Nov 4, 2002 | 11:56 AM
smokinHawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SS00Blue:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by smokinHawk:
SC-
E-mail me, and I'll explain more, if needed.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I under stand what your saying,
I thought since the wastegate is only connected to the Crossover it would dump most of the exhaust gases from the passenger side. I realy think my wastgate has a big part in this.
I have a single set up, turbo tech. see sig
