power loss after I sprayed with blower
what kind of blower, how much boost? dry shot(really? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> ), stock botom end? what size injectors? what kind of fuel enrichment came with the blower? stock fuel pump? using atap? where did you inject the 25shot? tell us eveything but i bet you went lean and broke a piston.
If the car's power starts to fall off but doesn't totally cut out the first, easiest and least expensive thing that I would look for is a clogged/broken cat. The exhaust temp could have got hot enough to damage the brick inside the converter so it's really restricting flow as you build boost. If power cuts out like hitting the rev-limiter that would seem to be something electrical and I couldn't see how that would relate to your trip down the track. Mechanical engine damage should be seem throughout the RPM range.
If the car runs smooth in the low RPMs one of both cats may be the problem.
Tom
[QB It wont rev out to 5500.It is like I hitting the rev limiter with a loss of power. <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" /> [/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Have you logged your MAF frequency? When the frequency goes too high for the ECM to see, it feels just like a rev limiter. I had the same problem that I traced to a six foot MAF extension harness. I replaced it with a 3' and moved the MAF, and it was fine.
Good luck.
-Geoff
Charles
