P1SC only goes into boost some of the time
It sounds like you have a major leak someplace.
I thought I had a leak too, but the only problem is that it is only some of the time. The only thing I could think of that would cause that is the bypass valve. I'll have to try adjusting it and see what happens I guess...
Went for a little drive at lunch. Only saw 3# max. When I got back to work and popped the hood to see if I had any dust anywhere I noticed that my 8 rib belt has turned into a 4 rib belt between last night and today
Perhaps I'll lay off the spirited driving until my new belt arrives tomorrow
So I concluded my boost gauge must be hooked up wrong, or a leak in it or something. Turns out I had my boost gauge hooked to the line that comes out of the back of the manifold, but after a little check valve. No problem- moved it to the same place I was tapping into the bypass and vuala! about 6~7# showing on the boost gauge now at WOT at 5500 RPM
Now gotta get her fine tuned on the dyno, then off to the track
