Replacing Stock Regulator !/MightyMouse
Old Nov 19, 2002 | 02:31 AM
spectra57's Avatar
Default Replacing Stock Regulator !/MightyMouse
Does anyone know who carries an upgraded intank fuel pressure regulator? 2000 camaro SS Thanks.
<small>[ November 21, 2002, 05:34 AM: Message edited by: spectra57 ]</small>
Old Nov 19, 2002 | 05:37 AM
smokinHawk's Avatar
Default Re: Replacing Stock Regulator !/MightyMouse
is this for a Forced induction car.
Best to get a boost reference regulator.
Aeromotive makes some good ones.
So does Charged Air
I think Im going to get the Charged air because its vacuum and boost regulated.
Old Nov 19, 2002 | 09:38 AM
spectra57's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by smokinHawk:
<strong>is this for a Forced induction car.
So does Charged Air
I think Im going to get the Charged air because its vacuum and boost regulated.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes it is for a forced induction car. My question is if I get a boost reference regulator from Aeromotive will that go in the tank where the stock one is ? And if not will I then need to upgrade to a returnable fuel system to make this work? Thanks.
Old Nov 19, 2002 | 11:39 AM
smokinHawk's Avatar
some put it up in the engine compartment, others have put it near the tank.
not quite sure on how to upgrade it for the conections, as im still on stock myself.
Old Nov 19, 2002 | 05:39 PM
MIGHTYMOUSE's Avatar
to install a regulator you need to drop the tank, go inside and yank out the stock one.. then get some fuel injection hose/band clamps and put the new one somewhere in the return line around the axle area.. cut the stock return line in 2 spots if needed, and put the regulator in between, a few people on here have done this, then just runa vaccum line back to the rear end.
Old Nov 19, 2002 | 05:52 PM
Blackbird's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">cut the stock return line in 2 spots if needed, and put the regulator in between</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">or you can do it without cutting <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
one of these days I will snap the pics so I can show you all.
Old Nov 19, 2002 | 11:25 PM
spectra57's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MIGHTYMOUSE:
<strong>to install a regulator you need to drop the tank, go inside and yank out the stock one.. then get some fuel injection hose/band clamps and put the new one somewhere in the return line around the axle area.. cut the stock return line in 2 spots if needed, and put the regulator in between, a few people on here have done this, then just runa vaccum line back to the rear end.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">OK .I understand everything except the part about running a vaccuum line back to the rear end. Where is it going and what is it for?What regulator (p/n#) do you suggest?
<small>[ November 19, 2002, 11:52 PM: Message edited by: spectra57 ]</small>
Old Nov 20, 2002 | 06:00 AM
smokinHawk's Avatar
I thought the regulator was up front conecting the fuel rails.
hmm learn somthing new every day.
Old Nov 20, 2002 | 09:08 AM
spectra57's Avatar
<strong>I thought the regulator was up front conecting the fuel rails.
hmm learn somthing new every day.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That thing connecting the fuel rails is a pulse damper ,I believe.
SmokinHawk, Where does that vaccuum hose go to ?
What regulator do you suggest P/N# and brand? Thanks.
<small>[ November 20, 2002, 09:11 AM: Message edited by: spectra57 ]</small>
Old Nov 20, 2002 | 11:24 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
The vaccuum hose has to go to the regulator so it knows how much vaccuum/boost the intake manifold (and consequently, the injectors) see. If it doesn't have a vaccuum line, it doesn't know whats happening inside.
Old Nov 20, 2002 | 11:26 PM
spectra57's Avatar
OK , so I run a vaccuum hose from the regulator to the manifold? Where exactly does it connect to?
Old Nov 21, 2002 | 12:00 AM
tap into the manifold somehow, most easy is to T off of the line that is on the back of the intake with some pep boys supplies this goes on to the regulator where there is a nipple for it to slip over.
the referenced regulator raises/lowers fuel pressure with manifold pressure so that the fuel tuning does not have to change to compensate for the extra/lack of fuel when it is sucked out of/pushed back in the injectors..
50# fuel and 5# boost is the same as 45# fuel to the tuning. get me?
blackbird, i once had the incon regulator which didnt work but it came with a nice line that you just snap in between the stock return line where it turns from metal to plastic over the axle, that was nice. i figure it is tough to not cut the hardpipe and do it another way without dropping the tank. OR replace the whole return line with something different.
Old Nov 21, 2002 | 01:04 AM
spectra57's Avatar
MIGHTYMOUSE
Member # 685
You have drawn me a pretty clear picture, Thank you.
Old Nov 21, 2002 | 01:29 AM
spectra57's Avatar
MIGHTYMOUSE
Member # 685
I was checking out your photos of your fuel system. Looks really good! Where did you get those fuel rails?
Old Nov 21, 2002 | 10:47 AM
thanks, the rails, regulator and fuel filter were from www.ls1speed.com
the lines and fittings were from www.jegs.com
i havent tried it but i'd imagine pretty much any high pressure fuel regulator can be used long as you can hold it in place inside the tank without leaks.. everyone i know of that has upgraded has moved it outside the tank for the obvious easier adjustments. talk to blackbird or maybe cablebandit about how they mounted theirs/hound them for pics.
Old Nov 22, 2002 | 12:46 AM
spectra57's Avatar
Thanks, your photos are great and a big help <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
