Paging Ed Potter from LPE!
Old Nov 21, 2002 | 06:20 AM
NoOne's Avatar
Default Paging Ed Potter from LPE!
Ed,
I know in the past you have offered to help out with selling parts people may be missing for their Incon kits.
How about the mechanical oil pump and bracket???
I would KILL to get ahold of one of these and so would alot of people who have played scavenge pump go round.
I just put the car up for the winter and am sure in the spring I'll be sprinkling the driveway with oil while I change the pump, they never last the cold it seems.
Thanks
Old Nov 21, 2002 | 08:42 PM
Stenod's Avatar
LS1TECH Sponsor
Default Re: Paging Ed Potter from LPE!
I know i would be interested in changing my stuff too! This is my only complaint about the incon kit <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Let me know what is involved eric, thanks
Joe <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old Nov 21, 2002 | 09:15 PM
red ws6 99's Avatar
For a mechanical oil pump just go to razorperformance. www.razorperformance.com they make the pump for lpe, katech, asa use. They made a custom one for Harlan.
Gary
Old Nov 22, 2002 | 05:29 AM
NoOne's Avatar
Red,
They make the pump but do they make the elusive bracket that LPE designed so it all packages real nice without removing anything?
Thats what I'm looking for.
Old Nov 22, 2002 | 06:48 AM
red ws6 99's Avatar
If you know the dimensions they will make you one (razor), but your right its a lot easier to have someone else measure the location of the two EGR mounting holes (or similar). I decided to go with a weldon electric, since rumor was that lpe switched to a different pump. The pumps need rebuilding quite often so it was not a option for me.
Gary
Old Nov 22, 2002 | 07:15 AM
Ed Potter @ LPE's Avatar
Closed ex-Sponsor Account
Hi Guys -
Let me try to clear a few things up on the scavange pumps.
We originally used the Incon supplied pump, which did not have hard anodized pieces. those pumps eventually wore themselves out! we ended up making our own pumps to the same specs, and all of the pieces are hardened to ensure long pump life. We make everything here for the pump, including the bracket & pulley.
The Razor pumps are a totally different pump, used as a scavenge pump in a dry sump oiling system for ASA engines.
I would be happy to fix you guys up with a pump & bracket, just let me figure out a price, and make sure it will fit the F-body as is.
Ed
<small>[ November 22, 2002, 07:18 AM: Message edited by: Ed Potter @ LPE ]</small>
Old Nov 22, 2002 | 09:14 AM
NoOne's Avatar
Ed,
Incredible!
That would be awesome. Where does the pump mount?
The F-body pump mounts under the front bumper support dead center, I'd need to source some new hoses but to finally be done with the oil pump problem would be awesome.
Thanks!
Old Nov 22, 2002 | 11:58 AM
NoOne -
Our pump mounts to the drivers side cylinder head,and runs off of the factory serpentine belt. We do run a longer belt, and can supply the belt #. you will need to run your own lines, we usually bend hard lines that run from the factory oil galley in the block, and then down to the scavenge tanks. I'm still trying to figure out a price,since we've never sold them out the door.
I'll post as soon as I have it.
Ed
Old Nov 22, 2002 | 02:27 PM
Mark C's Avatar
I almost did not look at this because of the topic.
Damn, NoOne, nice idea. And you're right about the cold. I was just about to order another diaphram in anticipation.
And driven off of the serpentine belt! Beautiful.
Old Nov 22, 2002 | 02:35 PM
y2khawk's Avatar
Ed
Just a couple things to be aware of...
Due to locations of the accessories on the F-body, the driverside head is not an option. Our power steering is in the way. The pass. side head w/ replacement of the tensioner is a better choice.
Second, the placement of the belt path is different from f-body to y-body. IE front of cover to belt centerline distance is different.
Say hi to Jayson for me <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 22, 2002 | 03:54 PM
sounds like we need to do a little R&D to make the pump fit an F-body, but that's no big deal. We definately want to sell you guys pumps, so if we need to make a different bracket, we will. I will round up an engine with F-body front dress, and start figureing out what we need to do.
I'll pass the message on to Jason
Ed
<small>[ November 22, 2002, 03:58 PM: Message edited by: Ed Potter @ LPE ]</small>
Old Nov 23, 2002 | 10:19 PM
O2BQIK's Avatar
As another f-body guy with a leaky pump on my Incon kit, I'd be interested too if the price is reasonable.
Old Nov 25, 2002 | 02:31 PM
DaveSchott's Avatar
Put me on the list as well. I'm going to ditch the diaphram pump regardless, and a belt driven pump would be great.
Old Nov 25, 2002 | 04:23 PM
ChevyNo1's Avatar
Let me know too!
- Dug
Old Nov 25, 2002 | 04:25 PM
I was just talking with one of our engineers, and it looks like we can make a different spacer, and we will be able to use this pump an f-bodies.
I had the location wrong before, the pump actually bolts to the block, just below the front of the drivers side head.
give me a couple more days, and we will have a prototype that I can post a picture of.
Ed
Old Nov 26, 2002 | 03:30 PM
NoOne's Avatar
Sweet Ed!
I think everyone with an Incon kit would buy one, if not now when they get tired of replacing pumps, because if it hasn't, it WILL die sooner or later.
Thanks again
Old Nov 26, 2002 | 03:57 PM
Currdog's Avatar
I'd be interested, I haven't had a problem yet, but I'd rather replace it if it's going to be a problem.
Old Dec 3, 2002 | 05:11 PM
DaveSchott's Avatar
