What head gasket and bolts to use?
I tried about everything out there as far as head gaskets go, I finally have settled on extra thick solid copper gaskets with arp studs...
Last time the motor had to be rebuilt, we found the head gaskets didn't blow, and the bolts didn't stretch, but the head actually bent 0.020 in between the bolts. Damn aluminum is pretty but it bends too easy.... <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
I wonder if these LS1 heads could be "Pinned"?
I had Champion Heads in FL. "pin" my 89 Turbo Trans Am heads. It envolves drilling 3 holes through the heads and the having steel pins pressed in. This keeps the heads from flexing at high boost levels. This work is fairly common in the Turbo Buick community, but I have not heard about it here with the LS1 guys yet.
I would bet this would be the ticket for these LS1 heads too. The head lifting problem can be traced in many instances to actual head flexing.
Ron,
_______________________________________________
<small>[ November 28, 2002, 10:56 PM: Message edited by: Kimchee and Rice ]</small>
Cheapest place I've seen to get the studs is from Jegs, I believe you have to get cometic gaskets directly from cometic, I have a set of 0.060 dead soft copper ones in stock for my own car, just incase... I suppose i could sell them a replace them later, what exactly do you need?
<img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
