How much fuel pressure drop is acceptable?
Dips to 56psi ok? 54psi?
At what pressure do you start to worry and address the fuel system/pump again?
I guess my answer to your question would be: if the injectors are keeping the fuel to the motor it needs at whatever the fuel pressure is, you are ok.
I think one guy dipped to 52# and lost his motor.
<strong>True about the injectors. Just trying to draw the line as to where I should be concerned.
I think one guy dipped to 52# and lost his motor.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Pressure is always going to lower when the regulator is wide open. Not much pressure in a garden hose with no nozzle.
The guy lost his motor due to a whacked A/F, which is what you'd better be watching if you want to keep your engine alive.
Trying to determine whether or not your engine is safe by the fuel pressure is like determining if you need oil by watching the oil pressure gauge. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
SC-
Withya. But assuming the A/F is tuned correctly (I will babysit it) at what fuel pressure is the pump not keeping up and should be upgraded?
I assume fuel pressure of 40psi would be bad? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Where should you draw the line an defining when the pump isn't enough?
Pressure drops down to ~50 weren't giving me any problems.
Good Luck,
Kevin
