What size reverse split cam 2 run for SC and Stock motor?
Old Oct 22, 2005 | 05:32 PM
GREATWALLTA's Avatar
Default What size reverse split cam 2 run for SC and Stock motor?
I am getting a Powerdyne super charger for my 02 Trans Am, and was wondering what size reverse split cam I should run with it. I have the up graded valve tran already with LS6 heads. But I was told that my current cam is not good for supercharger use. Please list detailed specs, brands, and how much power it will likely to gain. I will noly be runing 4.5 PSI of boost with the stock bottom end.
Old Oct 22, 2005 | 05:38 PM
onefastss223's Avatar
I just ordered a 222/230 .574/.580 114+4 lsa for mine from CamMotion. This is with a P1SC at 10lbs though...
chris
Old Oct 22, 2005 | 05:47 PM
sr71's Avatar
if it's the one in your sig, your current cam will be fine. a rev split is normally a turbo cam. a sc likes a traditional split or single pattern cam. the 224 single pattern has proven itself to be one of the best all around cams available. save your money and use it.
Old Oct 22, 2005 | 08:18 PM
I would love to use my current cam but I was told that it would'nt work with superchargers. I bought the current cam with forced induction in mind for the feauture but was told that it would'nt work with this supercharger. Does anybody else run a cam like mine with a supercharger set? My cam specs are 224/224 @ 114 LSA with 581/581 lift.
Old Oct 22, 2005 | 09:47 PM
Come on now is there no more input that you guys can give me on this?
Old Oct 23, 2005 | 12:55 AM
sr71's Avatar
that is the cam of choice of Andy @ A&A corvette specialties (site sponsor). he is THE sc c5 guru. call him. he will tell you just how well it works. he has installed that cam in his personal engines and in MANY of the c5's that use his blower kit. his kit is the best in the business for c5's. many, many corvette guys run his sc kit and that cam.
Old Oct 23, 2005 | 08:31 AM
engineermike's Avatar
I'm with sr71. That cam will be fine.
Old Oct 23, 2005 | 10:57 AM
Slowhawk's Avatar
LS1Tech Sponsor
If your seriously ussing the powerdyne I would run a small cam with a ton of LSA.The Powerdyne is limited by airflow so you want to keep as much pressure in as you can.
Probly something like 220/224 -.550 lift on a 118 duration.
Old Oct 23, 2005 | 11:41 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
That cam is fine, it's more about the increase in intake and exhaust duration to make power (generalization).
I would not do a Powerdyne unless you got it for free.
Old Oct 23, 2005 | 11:48 AM
Public's Avatar
What he said.
Old Oct 23, 2005 | 10:05 PM
Got Me SOM's Avatar
The powerdyne is only good for 5 lbs. You will want to make more power, trust me.
Go Vortech or ATI and leave room to grow with your setup.
