The beginning of something...
Old Nov 17, 2006 | 01:21 PM
  #141
Blown383's Avatar
Sweet car what happened to the 1st motor?
-B
Old Nov 17, 2006 | 01:35 PM
  #142
Frost's Avatar
A chicken and egg kind of thing with bearings and lifters... don't really feel like dragging it back out, there is a thread or two about it.
Old Nov 17, 2006 | 04:01 PM
  #143
obZidian's Avatar
just one step closer, car looks good with that open grill!
Old Nov 18, 2006 | 01:39 AM
  #144
Frost's Avatar
Oh yeah...
I have about 450 miles on the new engine
I've been running along at 8psi and I have alot left to do, but I'm hoping to bring the boost up about 3 psi tomorrow, and I'm hoping to be at 15psi by just after Thanksgiving. I'm trying to take my time with this and work has kept me VERY busy.
Old Nov 18, 2006 | 07:31 AM
  #145
OneMeanZ's Avatar
Hell yeah
Old Nov 19, 2006 | 09:16 AM
  #146
Frost's Avatar
MORE BOOST!!!
heh heh
Well I have the car up to 12.5 psi with about 14.5deg timing around the peak tq area moving up to 16deg by just after 5K and WOW what a step up from 8psi!!! I am at the limit of my fuel system for now. My wideband shows me leaning out to about 11.0 at the end of a pull from the bottom to top of 3rd gear.
My crappy street tires don't stand a chance
These things will top-fuel spin at highway speed I need to look more at the shoes the car is wearing now, first and second gear are totally and completely useless. Seriously.
Good stuff, took me for f'n ever to get here.
Old Nov 19, 2006 | 09:23 AM
  #147
Superman09's Avatar
LS1Tech Sponsor
Awesome Frost! Glad to hear the good news! What does your fuel system consist of?
I bet your waiting for those nbice 315 17" MT's to come out eh?
Great work
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 19, 2006 | 09:42 AM
  #148
Frost's Avatar
Great work
I had an issue with my eBoost controller, MM said, "look at this area" and he was dead-on, so it's less my great work and more his realization but nevertheless... (Thanks Mouse!)
YES GOD WHEN THE HELL ARE THE 315/35 17 ETSRs coming out already??
Fuel system right now is a Racetronix[walbro] in-tank pump, racetronix harness, MSD pump booster, -6 feed line, stock line for the return, Nasty Nate fuel rails, 60lb injectors, a front-mounted boost referenced fuel pressure regulator, and an Alkycontrol meth kit. I'm tuning with HPTuners. I'm kind of curious where the HP is at right now.... Should get the second pump and some other issues tied up over Thanksgiving.
Old Nov 19, 2006 | 11:52 AM
  #149
RW99's Avatar
Congrats, Frost... I need the 315/17 MT's too, now.
Your sig pic is great; do you have some sort of mesh in front of the IC or not?
Old Nov 19, 2006 | 02:10 PM
  #150
Blown383's Avatar
Add a second Walbro thats turned on by a hobbs swtich and you're good to go.
-B
Old Nov 19, 2006 | 04:53 PM
  #151
Frost's Avatar
Yeah there is something there that looks like chicken wire it just doesn't show in alot of photos.
How is your setup doing?
Old Nov 19, 2006 | 08:30 PM
  #152
RW99's Avatar
Life is good. Running around 11 psi or so:
Mine's a T67, though, so no "big" numbers. But plenty fun for now. You end up learning how to use "part throttle". Not used to that.
I'm keeping a wary eye on everything; gaining some confidence in the car's reliability. Knock on wood, so far so good.
Old Nov 19, 2006 | 10:08 PM
  #153
obZidian's Avatar
what was wrong with your e-boost?
Old Nov 19, 2006 | 10:19 PM
  #154
Frost's Avatar
Vacuum line routing
Old Nov 19, 2006 | 10:25 PM
  #155
Frost's Avatar
RW99 -
The graph looks full of torque
After being stranded by a thrown and shredded belt, and worrying about stuff burning up I know how you feel. So far so good for me too. What does your timing look like across the board at WOT? What is the CR of your engine? That thing is way safe rich Mine leans out to 10.8-11.0 above 6K and that's on meth I purge the meth and see it hit the wideband before I put my foot down. I'm hoping to have a second pump in there by the end of the week when I'm off.
Old Nov 20, 2006 | 08:33 AM
  #156
onfire's Avatar
Coal Mining Director
If you "lean out" to 10.8 -11.0.....how rich are you running?
Old Nov 20, 2006 | 09:19 AM
  #157
RW99's Avatar
Frost, I'm not the tuner so I can't tell you what's in the tables... but logging timing while at WOT shows me 18 degrees or so. I'm around 9.2 for compression.
BTW, that graph above is on methanol. I would think that you wouldn't actually have to worry until you get close to 12.0, would you? I wanted mine to be 11.5 max, but I'm trying to go extra safe.
Anyway, two pumps (with the second boost-actuated) is definitely the way to go. Mine's set up that way and it's overkill.
Old Nov 20, 2006 | 09:37 AM
  #158
Frost's Avatar
Well, remember that this is on meth for time being, It'd be a point or so higher without it.... I am at 10.0-10.1 up until the pressure begins to drop.
Another reason to be so fat and light on the timing (even tho I'm at about 8.6:1 CR) is that when my buddies and I had the M6 out the other weekend, I lost feedback from both knock sensors This coming holiday (end of the week) I'm swapping intakes and will be addressing the knock sensor issue then and will feel a little better about leaning things out and adding timing.
Old Nov 20, 2006 | 09:40 AM
  #159
Frost's Avatar
... I would think that you wouldn't actually have to worry until you get close to 12.0, would you? .....
No I agree, but without the meth I would be in the 12.0-12.2 range from what I have seen at lower boost (the AFR drop with the meth at the same level) and it's just out of fuel. I'm at 12.5psi of boost on the one pump as it is, I should be just fine after the second one goes in.
Old Nov 24, 2006 | 08:12 PM
  #160
Jimmyz's Avatar
Holy Moly!! Thats a ton of STUFF
