AFR or EGTgauge
Old Jan 10, 2003 | 06:16 PM
Big Stick's Avatar
Default AFR or EGTgauge
Which is a better indicator of proper / improper fuel provision in a single turbo car. I'm not looking to tune with it, just have an early warning system in case things get out of whack.
Old Jan 10, 2003 | 07:25 PM
LS1astro's Avatar
Default Re: AFR or EGTgauge
I think an EGT gauge is more accurate and easier to setup good then an AF gauge. An AF gauge will tell you if you got enough fuel but a EGT gauge will tell you if your fuel has enough octane to not burn up your motor.
Old Jan 10, 2003 | 11:48 PM
red ws6 99's Avatar
Both a wideband o2 and egt on each cylinder.
Gary
Old Jan 11, 2003 | 07:42 AM
MIGHTYMOUSE's Avatar
i think he was looking at staying practical <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
i would get a good fuel pressure gauge, very necessary.
as an early warning system, i think the a/f gauge would show a abrupt change quicker.
Old Jan 11, 2003 | 09:46 AM
red ws6 99's Avatar
I was being serious. I already have a wideband o2 and have ports in my exhuast manifolds for 8 egt ports. Spend another $200 and you can record the egts.
Gary
Old Jan 11, 2003 | 11:06 AM
Big Stick's Avatar
Ummm, I don't have the money for a wideband O2 and 8 point EGT. Besides it's a bit overkill for a WARNING system don't you think? I'm not looking for a tuning tool (That will be done on a dyno)
Anyway, what I'm concerned about with the AFR gauge is too much info. The way the AFR gauges work with the lights and all, it seems to me that it deminishes in value as you begin to ignore the "pretty light show". Is this a valid concern? Also, what's the practical utilization of the EGT? In other words, what is a "normal" reading vs lean / problematic?
Thanks for your help.
Old Jan 11, 2003 | 03:31 PM
lbz34's Avatar
Use an egt gauge. A wideband is the only a/f gauge i would even consider, but at the price go with an egt. High egt readings on a FI car are 800 deg. Do not buy the autometer egt get a good one (greddy one is great for 150+-). you shouldnt get too much over 800 deg. on WOT 4 th gear pull. Not enough timing can cause high egt readings along with not enough fuel. You can find greddy gauges online.
Sean
Old Jan 11, 2003 | 08:42 PM
red ws6 99's Avatar
Wear are you measuring 800 degrees. That is extemely low, most of the temperatures I have seen are at least 1500 deg or higher.
Gary
