whats this guy using to build boost?
Old Oct 25, 2005 | 03:35 PM
Ferocity02's Avatar
Wouldnt an explosion through the turbo shorten it's life?
Old Oct 25, 2005 | 05:09 PM
DMH Fabrication's Avatar
a 2 step does not hurt the turbo but anti lag will shorten how long it lasts(not sure on how much damage it really does if you don't use it much).
Old Oct 25, 2005 | 11:55 PM
99SS-T's Avatar
So to do this in our cars what woudl we have to do? Liek what all equipment? Thanks
John
Old Oct 26, 2005 | 12:00 AM
eviltwins's Avatar
AEM anti-lag is definitely bad for the turbos. I havn't set it up again because it's really no use to me, but I had no problem bringing my small frame 88mm up to 20 pounds of boost on the line with anti-lag plus 2-step. I used it so much that I overheated and stress cracked the turbine housing, ate up the seals, and melted my exhaust. My downpipe starts off with about 2.5 feet of stainless, then I have an aluminum dump coming out just behind the rear passenger tire. That was all melted and deformed and I couldn't undo the V-band clamp, had to cut it off. Fun as **** though. It's even nicer in a buddies AWD eclipse with a GT40R, talk about sickening launches. To use the anti-lag you need to buy an AEM EMS system, although I don't know if anyone is even running one on LS1 camaros.
Old Oct 28, 2005 | 05:59 PM
blackz93's Avatar
Yeah definitely "anti-lag"!!
Retards the **** out of timing and dumps a shitload of fuel to keep the turbo spooled.
Alot of turbo road-race cars use this for going into corners and stuff. Keeps the turbo spooled so they will be in boost when they power out!
Old Oct 28, 2005 | 07:56 PM
fastlt1's Avatar
You got a link or part number for this thing?
Old Oct 29, 2005 | 02:49 PM
eviltwins's Avatar
www.AEMPOWER.com, it replaces the entire ECU and the anti-lag is just a feature of it.
Old Oct 30, 2005 | 10:47 AM
turbo'd stang's Avatar
I don't see why you couldn't do the same with a multi-stage boost controller. Build boost on the line, after the you let off the t-brake, xx boost comes on. So many nanosecs later more boost comes in etc..... x 4. Those help tons on a small tired car with alot of power. I could tell you where I got mine from, but I'd have to kill you..
Old Oct 30, 2005 | 11:03 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
damn that car was all over the place
do tell
Old Oct 30, 2005 | 11:06 AM
ABeasst's Avatar
innovative makes one and you can get it through LS1speed only drawback is the price
Old Oct 30, 2005 | 01:46 PM
eviltwins's Avatar
A multi stage boost controller is nothing like what the anti lag provides for you. Anti lag cuts timing and DUMPS fuel so you get a raw fuel burn inside your header and turbine housing, to spool the turbo when you ordinarily wouldn't have enough exhaust flow to do this. A multi stage boost controller doesn't help up with spool at all, and people with a standard don't have the advantage of a trans brake.
Old Oct 30, 2005 | 07:55 PM
  #32
quikturbo's Avatar
Everyone has pretty much been accurate. I'm using an AEM EMS (my SC300 in the video), which allows me to launch on a 2step (I have set around 5600rpms) also utilizing anti-lag. I'm building about 28-30psi of boost on the line and with a 28" slick, I'm not spinning them to much at all. The car weighs about 3875 with me in it, so it's a bit of a pig to launch so I'm damn happy with a 1.36 60ft
I think the lack of my motors low-end torque, I greatly benefit being able to come outta the hole on so much boost. You guys are blessed with gobs of torque and don't need to come out on so much boost
I've heard one turbo mustang go off a 2step and it was freakin badass though
Chris
Old Oct 30, 2005 | 08:33 PM
  #33
nice ride where in il
Old Oct 30, 2005 | 08:35 PM
  #34
qqwqeqwrqwqtq's Avatar
Good to see you here Chris, your Lexus is a killer ride
Old Oct 30, 2005 | 08:47 PM
  #35
turbocuda's Avatar
Moparnos, nice to see some fellow mop-heads on the site....Sick lexus also....running the 2jz or the sc300 motor.....just plain siccckkkk!....You also seem to have the anti-lag enabled between shifts also....keeps her spooled up good fashion!
Old Oct 30, 2005 | 09:05 PM
  #36
fastlt1's Avatar
What is your specs?
Old Oct 30, 2005 | 09:24 PM
  #37
fastlt1's Avatar
What is your specs?
Old Oct 30, 2005 | 09:27 PM
  #38
quikturbo's Avatar
Thanks Jim, you know I feel the same way about your beast!!!!
Moparnos, I'm over in Bloomingdale.
fastlt1- well, to be brief, supra motor (gte), GT42 turbo, supra 6spd, cams, SP intake manifold.
The passes were all done on BONE stock block. Car still has a/c, heat, nothing has been removed, and weighs in at 3875lbs with me in it. 8pt chromoly cage.
I drive it all to and back from the track over 50+ miles with my stereo blasting
Unfortunately, next time to the track, more timing, more octane, more boost = lots more power, and a rod took a crap. I shut down going into 4th and ran a 9.97@117mph. I'll be building the motor this winter so it can actually take more power.
Chris
Old Oct 31, 2005 | 07:00 AM
  #39
chuntington101's Avatar
anti-lag does shorten the life of a turbo, but most standalone ECU's have adjustable. so you can set it up for the street and just have it pop and bang like hell and do nothing for the spool up but look good! or you can set the thing like the WRC rally guys do and make boost at idle!! but at these sorts of levels it will cook turobs pretty quickly!
an funny alternative i read about earlier today was a guy using a helicopter jet engine to drive the turbo!!!! it was constantly spooled and dident lag at all! plus it sound F*CKING amazing on the start line as he wound up the jet engine!!!!
im (kind of in a really strange sort of way) that i haven't see anyone using a system like it before! or running a turbo like a jet egnine and then just taking off boost for the engines!!!! 45psi and instand boost anyone???? hehehehehehe
thanks Chris.
Old Oct 31, 2005 | 02:50 PM
  #40
99SS-T's Avatar
So to do something liek what the lexus does, but with our ls1's we would have to buy the EMS standalone setup? Doesnt BS3 or the other standalones that most people here use have a feature like that? Thanks
John
