Another 42# injector question.....
Old Jan 22, 2003 | 09:44 AM
2000silverbullet's Avatar
Default Another 42# injector question.....
I have just installed a 7# pulley (P1SC) and tried to install 42# svo injectors. When I was done my car felt as if there was a big vacuum leak; I even sprayed carb cleaner on the injectors and the idel went back to normal for a few seconds. Can you put 42#er's in and it run some what right? Or is it a must to immediately tune your computer? Any help would be great.
Old Jan 22, 2003 | 09:53 AM
BLMONGOOSE's Avatar
Default Re: Another 42# injector question.....
I did the same thing, The car will run for about 2 minutes then the plugs will get fouled up and it wont run anymore.
You have to tune it imediately!!!
Old Jan 22, 2003 | 09:49 PM
cablebandit's Avatar
look at it this way....our stock injectors are 26/28# at 58psi of fuel pressure. The svo42# are rated at like 43psi of fp (yes I could be wrong about the exact figure) At 58 psi, the 42#ers are more like 49# injectors. A SIGNIFICANT increase over stock. You cannot just throw them in and drive. a MAFT may make it driveable but it will still suck until you get it tuned
Old Jan 23, 2003 | 12:49 AM
Anybody else with 2cents? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 23, 2003 | 07:19 AM
Black LS1 T/A's Avatar
Moderator
I've read the Ford SVO 42#'ers are flow tested at 39.1 PSI instead of the 43.5 standard.
Can anyone point me to a reference that settles this question for me?
Thanks!
Anyway, cablebandit's point is definitely right-on, in any case. You gotta tune for those injectors!
