Has anyone attempted this?
Old Oct 26, 2005 | 10:54 AM
CHRISPY's Avatar
Default Has anyone attempted this?
Has anyone attempted dual log manifolds into a single or a twin turbo setup? (say 1 3/4 primaries into 3 inch log into each turbo)
Then going from going from dual 3 inch into single 3 or 3.5 inch pipe into a front mount intercooler.
It would be cheaper than full tubular manifolds, and still flow very well.
If you wanted to do single turbo you could do two log manifolds with the piping coming forward and merging into a single 3 inch pipe right at the turbo. You wouldn't have the backpressure issues like with the QTP and other crossover style kits and it would be cheap to make the logs plus you could route them exactly how you wanted.
You could also do dual 3 inch log with 1 3/4 primaries smoothly transition each pipe down to 2.5 inches, merge into a single 3 inch pipe into the turbo.
Thoughts?
It would knock a lot of time off fabrication that is for sure.
Cheers,
Chris
Old Oct 26, 2005 | 11:19 AM
will62085's Avatar
are you talking cold side tubing here? on my setup i used 1 5/8 primary headers into 3 inch collector to each turbo, then the cold side was 2.5 inch from each turbo that merges into a single 3 inch into the fmic, then 3 inch to the TB
Old Oct 26, 2005 | 11:26 AM
RyanJ's Avatar
SSU Moderator
Harlan/Stenod built one for an LT1 (twin turbo). He used thick weld-els for strength.
Old Oct 26, 2005 | 11:44 AM
CHRISPY's Avatar
That is EXACTLY what I am talking about!
cool, that should support a shiteload of power
Old Oct 26, 2005 | 11:46 AM
RyanJ's Avatar
SSU Moderator
sorry for the small pic. I have 4 or 5 more (some MUCH larger) which I pulled off of Harlan's site (can't remember the link now). I can email you if you want.
Old Oct 26, 2005 | 12:01 PM
CHRISPY's Avatar
Sure shoot me the email
Old Oct 26, 2005 | 12:09 PM
y2khawk's Avatar
http://harlan-engineering.com/tt_lt1/
the white TT car is kinda similar, if you can call stock cast manifolds logs.
Same idea anyway
Old Oct 26, 2005 | 12:11 PM
CHRISPY's Avatar
I cant tell from the pic but are they running the wastegates back into the downpipe?
Cheers,
Chris
Old Oct 26, 2005 | 12:17 PM
y2khawk's Avatar
yes, both sides
Old Oct 26, 2005 | 12:27 PM
CHRISPY's Avatar
cool that is what it looks like from the pics Looks great man!!
Have you thought about a vette log setup with twins and Air to air intercooling?
I have a test car here
Old Oct 26, 2005 | 12:28 PM
CHRISPY's Avatar
BTW That picture of Kramer is CLASSIC!!!
BTW check your PMs
Old Oct 26, 2005 | 03:29 PM
ls1chevy2's Avatar
I'm guessing no ones builds exhauste manifolds/headers like this on Natural Aspirated cars is because there's no scavenging effect, (that turbo cars don't care to much about).
What would happen if I used a set of log type headers on a NA car.
Old Oct 26, 2005 | 07:07 PM
libertine1015's Avatar
BTW check your PMs
Thats what happens when a guy buys "Art" without consulting the old lady, one look and its hanging out in the garage behind the tool box
Kind of like that commercial with the guy who hangs the 70's big fro black karate master picture on the wall and his wife makes him **** can it!!
Old Oct 26, 2005 | 09:24 PM
CHRISPY's Avatar
LOL I'd pay good money for that picture of Kramer, that show was pure genious!!!
Old Oct 27, 2005 | 07:51 AM
GMC SKI's Avatar
So how much power did the setup make ?
Do you think you lost huge amounts of power going with the logs ?
Old Oct 27, 2005 | 08:55 AM
LSONE's Avatar
IMO you're gonna need to fab up some sort of bracket to support the turbos weight so the manifolds dont crack. You're also gonna have to lay down some really nice fat welds.
Old Oct 27, 2005 | 09:30 AM
RyanJ's Avatar
SSU Moderator
You should see the thickness of the stainless used though. It will support those turbo's no problem. All these log manifold builders make the mistake of thinking they can use THIN 304 stainless and it will take the abuse. That's dumb. Bottom line, you are not going to add that much more weight by using a big *** schedule 10 or 40 or whatever weld-el.
Old Oct 27, 2005 | 11:46 AM
CHRISPY's Avatar
I believe they ran 8s@155mph plus on the log setup but I am not positive
Old Oct 27, 2005 | 11:48 AM
RyanJ's Avatar
SSU Moderator
Well, that's with the cast iron manifolds.
I heard about a guy running low 9's on some logs on a BBC in a second gen camaro. I dont have any pics, though.
Old Oct 27, 2005 | 12:54 PM
y2khawk's Avatar
The 6.0 manifold setup ran 8.84@155
The log manifold car has been over 700 rwhp at 15psi, mild 355 LT1 build, 230ish hydraulic cam, AFR headed, LT4 intake. it's been in the 10's with the 6 speed, but the owner isn't a huge drag racer. Thus the reason the exhaust has been toned down some, and it rarely sees a sticky tire.
Those logs are schedule 10 304 if memory serves. The runners were .125"+ thick and the log itself is over .25" wall. Heavy **** Strong though. Been on the car over 3 years now (i think it's close to that long) no cracking.
