Questions about 6.0L heads....
Old Jan 28, 2003 | 10:14 PM
BIGBOS's Avatar
Default Questions about 6.0L heads....
It looks like I will be buying a pair of these soon...
73cc chamber will drop me down to 9.5:1 compression...
I'm gonna stick with the stock bottom end for now, and run these heads, with cometic gaskets and might do ARP head bolts while I'm at it...
Now for the 2nd time, you think my bottom end would hold up fine for a while until I get more $$ for a built motor....
Also I got 6psi last time it was on the rollers, how much of a drop to expect with the 6.0L's??
Thanks,
Bos
Old Jan 28, 2003 | 10:32 PM
bfongC5's Avatar
Default Re: Questions about 6.0L heads....
Stock 6.0 heads are 70cc's which is not too far from the stock LS1's of 67. I do not know if you meant that you are going to open up the 6.0's to 73cc's.
I have a set of 6.0 heads that I am planning on using. I might have a spare. I will look into it if you need a set.
Bill F.
Old Jan 28, 2003 | 10:36 PM
BIGBOS's Avatar
They would be a stage 2 TEA most likely, I would assume that would open it up to a 73cc chamber...
Old Jan 28, 2003 | 10:47 PM
Blown Hawk's Avatar
What do you mean "open" them up to 73cc's? How much do 6.0L heads go for? These are the heads I was looking to for the future. Thanks guys.
BH
Old Jan 28, 2003 | 10:48 PM
BIGBOS's Avatar
I was informed that 6.0L heads were 73cc chambers, I e-mailed TEA about it... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Might have to special order it
<small>[ January 28, 2003, 10:50 PM: Message edited by: BIGBOS ]</small>
Old Jan 28, 2003 | 10:55 PM
bfongC5's Avatar
Stock they are 70cc's.
Old Jan 28, 2003 | 11:02 PM
BIGBOS's Avatar
Ok, I got it all straight now, I got to order the 73cc option, its a no charge option though, so its all good.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 28, 2003 | 11:27 PM
VINCE's Avatar
Shorty Director
I think 6.0L heads go for around 450 bare.. Contact Valvegod.. He has them..
Old Jan 28, 2003 | 11:36 PM
BIGBOS's Avatar
Does valvegod sell LS1 blocks and LS1 cranks seperatly?
Old Jan 29, 2003 | 12:27 AM
ZYA_LTR's Avatar
Yes BIGBOS Shaun is his name, the shop is called SMC Performance, in Pontiac, Michigan, i think, not sure of city, but i know how to get there, i deal with him often, he sells them separate, and is super affordable, tell him Jason from Mach Performance sent ya, he'll take car of you for a fair price, i think the last time i talked to him, 6.0l heads were like 500/600 bucks.
<small>[ January 29, 2003, 12:29 AM: Message edited by: ZYA_LTR ]</small>
Old Jan 29, 2003 | 05:54 AM
smokinHawk's Avatar
must be going up i think i payed 350 or 400
and stock the 6.0 heads are 70cc, i had mine checked when i got them.
Old Jan 29, 2003 | 08:21 AM
turbolx's Avatar
FWIW, I have a car sitting here that has unported 6.0L heads on top of a stock rotating assembly (including cam) with twin turbos at 10psi. It makes over 510rwhp and 540rwtq on my Mustang Dyno and 93 octane pump gas. You really shouldn't have too much trouble with 6.0L heads and 6 psi unless the tune is WAY off.
Old Jan 29, 2003 | 03:07 PM
BIGBOS's Avatar
TEA is currently out of 6.0L cores, but they offered to do a 5.7L head with a 73cc chamber, advantages/disadvantages?? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 29, 2003 | 08:33 PM
VINCE's Avatar
Shorty Director
Well the 5.7L do not flow as well as the 6.0L's according to some. Jason99ta compared the flow characteristics of 6.0L heads to LS6 heads and the 6.0L heads flowed better in the low and midrange unported. The ls6 shined in the upper range..
Old Jan 29, 2003 | 09:22 PM
SStolen's Avatar
I was told 6.0L heads would drop the c/r to 9.7-correct? Also, if 6.0L heads flow better than LS6's then why would people go to 4.8L heads when going NA (How much does 4.8L heads raise the c/r?) I know 6.0's drop the c/r down but isn't flow what its all about? It would seem the 6.0 would be better regardless of N/A or F/I. Also, why is lower compression better on FI?? I'm new. Thanks.
Old Jan 29, 2003 | 10:43 PM
BIGBOS's Avatar
I was informed that the only advantage to the 6.0L head is the better exhaust port, I was told that was the only real advantage..
I went ahead and ordered the TEA S2 5.7L 73cc head, that will drop me to 9.5:1 compression... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 29, 2003 | 11:17 PM
BIGBOS's Avatar
Also when I hit 6psi last time I dynoed, and that was about 10.6:1 compression...how much PSI will I lose dropping the compression a point?
Old Jan 30, 2003 | 05:47 PM
Blown Hawk's Avatar
Do 6.0L heads come from one of the truck engines? Are they aluminum heads? I've been getting a little confused on how Litres, Cubic Inches, and compression ratio tie together. Can someone explain in a little bit of detail how the numbers work? I realize dropping the C/R is always a benefit to boost, but are there other advantages to the 6.0L heads(ie supposedly larger exhaust ports)?
BH
Old Jan 30, 2003 | 07:49 PM
Holes02's Avatar
Yes, to answer your first question, the 6.0L heads are out of the GM trucks. They're aluminum heads used in the 6.0L variant of the LS1 engine.
Because the 6.0L heads are used on a slightly bigger engine, the cc of the combustion chambers are also slightly larger. Because the chambers are slighly larger, the overall compression ratio is dropped. Another added benefit is that the ports on the 6.0L heads are also slightly larger then the 5.7L heads. As was stated earlier, they actually flow about even with a set of LS6 heads which is also a plus when you're forcing a lot of air thru the engine (as you are in a boosted application).
With a boosted engine, the use of slightly thicker head gaskets (which is another method of increasing combustion chamber size), will also slightly lower compression. Thats why people opt to run 6.0L heads along with the thicker headgaskets when building a low compression motor isn't an option.
Old Jan 30, 2003 | 07:57 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Dropping a motor a full point of compression is supposed to be a 3% reduction in total power... I'd look for corroboration on that.
We reduce compression to lower the octane (cooling properties of gasoline).
Higher octane just cools down the mixture so that we don't have early, or pre-ignition going on in the cylinders.
