PTE-63 Installed
Old Jan 30, 2003 | 09:51 PM
EARTH MOTORS's Avatar
Default PTE-63 Installed
I removed t-60 and installed PTE-63 , and a coan 2800 coverter,got trans rebuilt also.
The stock trans lasted 4 days with the 60-1
stock spag broke,
Trans shop installed heavy duty sprag?
Will this last very long .
Old Jan 31, 2003 | 05:50 AM
smokinHawk's Avatar
Default Re: PTE-63 Installed
Hope it holds together.
Have you been to the track yet?
Old Jan 31, 2003 | 10:27 AM
rodent's Avatar
Where did you get the motor mounts for the 72? Did you make them? How difficult was the wiring? Thinking about sticking a 6.0 in my 87 K5 and taking out the 496BBC.
As for the tranny, why not go with a 4l80? You have plenty of tunnel room.
<small>[ January 31, 2003, 10:29 AM: Message edited by: rodent ]</small>
Old Jan 31, 2003 | 09:39 PM
No track times waiting on Ed Wright to finish tune up.
Motor mounts I used 2002 4x4 fram mounts welded to my 72 cross member on a 73 up truck ,
I bolted a plate to the 4 bolts on the block,
and wealded the clam shell to it .
Wiring was simple use a GM harness pin out manual
the trans i had , wish i would of got a 4l80 ,
