How much timing on 7 psi ATi
Old Feb 20, 2003 | 07:39 PM
cdk4219's Avatar
Default How much timing on 7 psi ATi
Where is a good starting point for the timing on a stock engine with exhaust and a p1sc kit with the smaller pulley on it? I am running 42LB injectors.
Old Feb 20, 2003 | 08:05 PM
Texas Terminator's Avatar
Default Re: How much timing on 7 psi ATi
what are you tuning with? do you have a scanner of any sort? intercooled right? extra pump? cold tstat? how many rpm do you want to turn(boost is porportonate to rpm)? how long do you want it to last? plan on rebuilding/replacing your transmission soon?
did the plumbing that came with yours suck as much as mine did? <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Feb 20, 2003 | 08:34 PM
Blackbird's Avatar
18
Old Feb 20, 2003 | 09:10 PM
cdk4219's Avatar
Cold T stat Large intercooler(22x12x3 with 3" inlet and outlet) in a light car(2900lbs) with 390 gears. 255lph pump LS1 edit with wideband O2 on dyno, and Snap On scan tool.At what rpm should 18 degrees be seen?
Old Feb 20, 2003 | 09:14 PM
2001bird's Avatar
is the 255 an inline or intank. A single 255lph is cutting it kinda close!
Old Feb 20, 2003 | 09:29 PM
cdk4219's Avatar
In tank. I do have a pillar mounted F pressure guage for keeping an eye on it. What is the stock LS1 pump rated at?
Old Feb 20, 2003 | 11:05 PM
BIGBOS's Avatar
I am running 18degrees @ 4psi... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 21, 2003 | 08:54 AM
Black LS1 T/A's Avatar
Moderator
I ran 22 degrees at .80 to 1.00 kpa with zero to max 1.9 KR with 5 PSI (6000 RPM's) to 7 PSI (6600 RPM's).
I STILL ran 22 degrees timing running 10 PSI boost, but it took mixing 100 Octane with 93, or adding 1/2 can of TORCO Octane Booster. I did that for street driving and mixed 100 Octane when I went to the strip.
The difference in power between 18 degrees and 22 degrees is substantial. But, you got to be willing to do what it takes to keep KR below 3.0 and detonation eliminated.
I personally don't stress over 1 or 2 degrees of knock retard. Audible knocking or greater than 3 degrees of KR I do something about.
Good luck!
Old Feb 21, 2003 | 08:56 AM
Moderator
PS: I ws only running 11.7:1 peak A/F ratio at the time I did this, too. With more optimized A/F, I may not have been able to do this... I don't know.
Running rich kills power, too.
<small>[ February 21, 2003, 08:56 AM: Message edited by: Black LS1 T/A ]</small>
Old Feb 21, 2003 | 03:37 PM
1slowCamaro's Avatar
How much of a power difference is there between 17 degrees and 22 degrees timing?
Old Feb 22, 2003 | 12:34 AM
LS1Bird's Avatar
I run 17. Since 91 octane comes out of the CA pumps, we tuned to that. Anything 18 or higher just put me into KR, and I didn't want that. I also run my A/F under 12.0, more like 11.5 - 11.6
I suppose I could make more than 462 on my stock engine if I got a bit more aggressive with tuning. But I didn't want to be a slave to that 100 octane mixed fuel on my daily commuter.
Mike M
Old Feb 22, 2003 | 12:39 AM
QuickSilver2002's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1slowCamaro:
<strong> How much of a power difference is there between 17 degrees and 22 degrees timing? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is a guess but I would say about 40hp if you can get there with no KR.
22 seems way too high at peek tq on pump gas. 22 up top might be good.
You need it to be a few degrees lower at peek tq and then ramp it up towards redline. I would start at 15 and add until you see KR.
Old Feb 22, 2003 | 11:46 AM
I might try and bumb it up a litte since I run straight 100 octane all the time. But I'll have to tune while using nitrous or I could set myself up for some problems. Still probably wont go over 20.
Justin
