who has ls1 edit file for twin turbo application
i was wondering if anyone had a file for twin turbo so i could use it as a baseline for my truck also does anyone have a file for 42 lb injectors if you have it please email it to me or give me some tips
tia
marc
tia
marc
Re: who has ls1 edit file for twin turbo application
how much boost are you going to run?
I have a 6lbs and and 8lb program.
My injectors are 42.5 lucas. With pressure set at 58PSI on my external fuel pressure regulator.
USE AT YOUR OWN RISK!!!!!!!
Let me know if you want it.
Charlie
Charlie
yeah email me your programs i just want them as a baseline, did you do the tuning yourself if you did do you have any advice i'm just trying to be prepared when i get my setup running
email is importfighter02@aol.com
thanks
marc
thanks
marc
I have to give credit to SPEED INC.
Jim there worked with me and came up with the baselines which then were tweaked on the dyno.
The 8lb was done at the track and worked all the way to 10PSI.
