Anyway to stop the STS oiling of the engine?
Old Oct 30, 2005 | 03:02 AM
CAT3's Avatar
Restricted User
Default Anyway to stop the STS oiling of the engine?
The PCV system STS provides seems to work, but makes a fricken mess. Wasn't to bad with only 4-5psi, now at 8psi +/- its blowing oil all over the damn engine and making a mess. Not something I'd want to deal with. Will a AMW Catchcan work where the little filter/baffle is or will it cause to much pressure?
Old Oct 30, 2005 | 11:21 AM
CAT3's Avatar
Restricted User
About time to wrap that lil breather with a Playtex Maxi Pad...with wings.
Old Oct 30, 2005 | 11:37 AM
Zombie's Avatar
Your oil problem is most likely coming from the oil fill cap. If you look at the cap there is only one tab that holds it into the neck. Just a little crank case pressure and it will pop up (you can pull it up by hand) and spray oil all over the place.
My solution to it was 2 zip ties. Put one ziptie around the bottom of the fill neck and leave it a little loose so you can get the other ziptie through it. Then run the 2nd zip tie aroud the fitting on the oil cap and through the ziptie at the bottom. Holds the oil cap in place and solved my oil spraying issues.
Old Oct 30, 2005 | 08:54 PM
Blackbird's Avatar
I ditched the sts pcv system all together and went back to what has always worked for me.
that is venting the valve covers to a catch can with a breather on top and a checkvalve in line with the pcv valve itself.
Old Oct 30, 2005 | 09:34 PM
CAT3's Avatar
Restricted User
Blackbird, sounds about right. I have been thinking of putting a Catchcan right before the STS breather/vent bullshit, in hopes the oil separates in the can and stops oiling the entire engine bay...bastards.
Old Oct 30, 2005 | 10:20 PM
00turboT/A's Avatar
Catchcan works good just keep it emptyed out or it will blow oil all over the place as well.
Old Oct 30, 2005 | 11:09 PM
buldogg's Avatar
Can anyone post pics of this setup
thanks
Old Oct 31, 2005 | 06:57 AM
Assassin's Avatar
did you get an sts hooked up on your car too?.... check out what I did, there's no vaccume while cruiseing but under wot no restrictions..... https://ls1tech.com/forums/showthrea...hlight=pcv+pvc
Old Oct 31, 2005 | 09:36 AM
CAT3's Avatar
Restricted User
No STS for me, yet, mines still bottle fed baby! Just tuning and wrenching on Corky (that would be Larrys 35thSS).
