are these parts necessary for turbos
tia
marc
ou dont need a turbotimer. Just let it cool for a minute after a hard run.
Blow off valve- I personally like them for a safety but at the low psi that ls1's see i do not see it as a problem. Cheap insurance though as you can get a used on on supraforums for like 60 bucks at times and if you don't like the noice just route it back into the system and it will muffle it
Steven
Turbo timer...
"Putt-Putt" your car to a dark area at night after just cruising lightly, NO boosting. Look at the exhaust housings. Yes! They are glowing red. Look again after two minutes (which is adequate for cool down). They're not glowing now.
It's up to you, but timers ARE totally necessary, especially for those of us without watercooled center-sections.
BOV-
With an auto, no. Not necessary because A4 drivers don't slam the throttle blade shut EVERY gear, where M6s do.
IF you hear compressor surge (like a chatter from the turbo) on ocassion, you may need a BOV, but with the volume of the pipes and I/C between the turbo and TB, it's REALLY unlikely that you ever shock the turbo.
JMO (sorry zturbo)
SC-
<small>[ March 06, 2003, 05:27 AM: Message edited by: SS00Blue ]</small>
Steven
