merge collectors??
Old Mar 8, 2003 | 10:11 AM
1dirtyZ's Avatar
Default merge collectors??
does anyone know if there is a benifit of running a merge collector on a F/I motor?
i know they help the scavanging of the combustion gases , but with boost the gases are forced out anyway.
what do you think?
Old Mar 8, 2003 | 03:53 PM
02BlackWS6's Avatar
Default Re: merge collectors??
That's a good question..I have FLP's and i would like to open up the merge section alittle. I'm installing a 8# ATI with heads/cam soon so i would think opening up the merge collector on the FLP's would help. I'll just get a 3 inch piece of t-304 pipe and have a muffler shop cut the squashed section and weld in the new piece of pipe. Just a thought.
Old Mar 8, 2003 | 03:58 PM
ZYA_LTR's Avatar
From what i have heard, merge collectors aren't worth the money on s/c cars, they are meant to scavenge exhaust gasses, and spped the flow more, but on s/c, you are already pushing the air in and out of a motor anyways, so it's not as much of a concern, if anything, i would think that the taper on a merge collector would hurt in a s/c application.
<small>[ March 15, 2003, 06:28 AM: Message edited by: ZYA_LTR ]</small>
Old Mar 9, 2003 | 10:06 PM
Monty's Avatar
Yes, you want to use a merge collector. Burn's Stainless and Specialty Products Design offer pre-made, double slip, turbo merge collectors featuring an internal diffuser cone. A 15* taper is typically ideal for most applications.
On street turbo applications, backpressure between the turbine and exhaust valves are typically 2x greater than manifold pressure (boost) so anything you can do to lower backpressure and increase efficiency and scavenging is beneficial. Of course there are plenty of non-optimized header/exhaust manifolds out there that work very well, but if you want to do it right, equal-length, tuned headers are still the way to go with turbos.
Old Mar 10, 2003 | 12:29 AM
1dirtyZ's Avatar
but that's on a turbo motor, how about a supercharger motor?? does this still hold true?
Old Mar 14, 2003 | 08:36 PM
Monty's Avatar
Of course, you still want to aid in scavenging the exhaust as much as possible. The exhaust side of an S/C motor is the same as a N/A motor, except it needs more help evacuating the exhaust since you are forcing more into the intake under boost. Look at any professional/race S/C or turbo car...
Old Mar 15, 2003 | 03:39 AM
Black LS1 T/A's Avatar
Moderator
Supercharged applications like big pipes, but exhaust scavenging does little for Supercharged motors. If you have the money to burn, go ahead. But, it could best be used for something else that will make a real difference.
