Thinking about boost
Old Mar 15, 2003 | 02:52 PM
whitt1's Avatar
Default Thinking about boost
I'm new to supercharging.I have questions about how much boost is safe.I have a new intercooled magnacharger installed on my Tahoe.The system is pretty much the same as the one installed on 03 cobras and lightnings.It uses the same aluminum intake as the C5 magnacharger kit,42lb injectors,a msd booster pump,superchips computer programing,and a heat exchanger hooked to a electric waterpump and front mounted radiator samwiched between the supercharger and intake manifold.My 5.3 has stock 9.5compression ratio,asm longtube headers,160degree thermostat,electric fans and homemade ramair.The system is rated at 7 1/2lb.of boost,not yet verified boost gauge and fuel mixture gauge are coming.How much boost can I safely make on 93 octane fuel.
Old Mar 15, 2003 | 04:45 PM
MEAN LT1's Avatar
Default Re: Thinking about boost
With your current compression, i would say you could safely run 10-12# of boost. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
