Mustang Blower on an LS1???
Old Mar 12, 2003 | 12:52 AM
98_WS6_M6's Avatar
Default Re: Mustang Blower on an LS1???
Pro Stock John,
Do you think that the S Trim will work on my car? Or do you think it will be too much boost? What is a YS Trim?
Keep me posted on your GP.
Old Mar 12, 2003 | 10:43 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Slow, I'll ask my Vortech contacts today about which other head units fit in that bracket. I should edit my S-trim comments, an S-trim is good for 6-15 lbs of boost but realistically 10-12 lbs would be the most boost that folks would be able to get out of one.
Slow, I might ask you a favor, if you have a digicamera, maybe you can take some pics of the bracket and measure up some stuff for me...
At the very least, for us to run a Vortech we would need:
-blower/head unit
-brackets
-crank balancer/pulley
-blower pulley
-oil lines for cooling
-inlet/outlet piping
... And probably other stuff.
If anyone would be seriously interested in a YS, T, or S trim bracket let me know and I will see about getting a GP price but I will require a deposit to pay for the bracket materials. Bracket will include tensioner pulleys too.
Old Mar 12, 2003 | 11:57 AM
slow's Avatar
sure no problem, i will take the bracket to my friends with a digicam, and take some pics.
Let me know what measurements you will need.
A friend has a A trim laying around from a stang, and from what i understand about the A to S trim conversion on a stang, its just unbolt A and bolt in S. So im assuming they are the same shape. I will do more research into this, and may try to bolt his A onto my car, to see how it fits.
Ryan.
Old Mar 12, 2003 | 02:30 PM
slow's Avatar
the discharge on a LS1 kit is straight, and the A/S from a stang uses a curved 90degree output. So thats the first drawback.
I understand that vortech can change output piping for $260 and you have to send it to them.
Ryan.
Old Mar 12, 2003 | 07:06 PM
98_WS6_M6's Avatar
Does Vortech have to change the discharge or can we do it ourselves?
<small>[ March 12, 2003, 07:09 PM: Message edited by: 98_WS6_M6 ]</small>
Old Mar 12, 2003 | 07:32 PM
slow's Avatar
im sure you could do it yourself, as i think thats not a precision part that would effect the balance of the blower, however, as far as i know, vortech will not sell the straight output piece uninstalled, call their tech line to find out for sure. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ryan.
Old Mar 12, 2003 | 10:06 PM
98_WS6_M6's Avatar
Thanks for the info SLOW
Pro Stock John : What do you think? Can you get the part through your contacts?
Old Mar 13, 2003 | 12:29 AM
98_WS6_M6's Avatar
That's probably right SLOW because the charger I'm buying is an S Trim in an A Trim Casing. Find out if your brackets will work with that set-up and let me know.
Pro Stock John: I am going to look/buy the blower tomorrow so I am definitely interested in the brackets.
<small>[ March 12, 2003, 12:37 PM: Message edited by: 98_WS6_M6 ]</small>
Old Mar 13, 2003 | 10:27 AM
98_WS6_M6's Avatar
ttt
Old Mar 13, 2003 | 10:57 AM
LS1Tech Co-Founder
My Stang friend said that most S-trims from Stands use that 90 degree bend.
What part are you wanting me to ask about?
I am going to use a straight outlet YS trim.
Old Mar 13, 2003 | 08:14 PM
98_WS6_M6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong> My Stang friend said that most S-trims from Stands use that 90 degree bend.
I am going to use a straight outlet YS trim. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">SLOW said that I would need a straight outlet for this S Trim in order for it to work on my car and Vortech will not sell the part. They will only sell it installed.
Anybody know what kind of ET and HP I would expect out of this blower with a TR224/227 cam and Stage II heads???
Old Mar 13, 2003 | 11:02 PM
  #32
slow's Avatar
ask if you can buy the straight output for the S trim. and if so, cost <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
And if it can be installed by an average joe, or is that one of the tight tollerence parts that vortech "really needs" to install.
you dont 'need' the straight to make it work, but if you look at the rest of the V9 G trim kit, thats how it works, so it would be the easiest solution, as shown in this pic.
<img src="http://www.carrollsupercharging.com/images/4gk218-010s_engine.gif" alt=" - " />
Thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Ryan.
Old Mar 15, 2003 | 12:11 AM
  #33
slow's Avatar
just talked to somebody, and found out that the bolt pattern on the V9's and the S/A trims are different, as the V9 is a smaller blower <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
So i dont think this will work, i'll still try to bolt the bracket i have to the A trim to find out, but after reading some of vortechs site, they comment on the V9 being a compact blower as well <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Ryan.
