PULLEY PROBLEM
Old Mar 15, 2003 | 07:31 PM
SS 35TH's Avatar
Default PULLEY PROBLEM
PROCHARGER D1SC PULLLING 15# BOOST.ON 2002 LS1 ENGINE TOTAL REBUILT TO 9.5 TO 1 COMPRESSION. PULLEY ATTACHED TO TORQUE CONVERT KEEPS COMING LOOSE. CALLED ATI AND ORDERED NEW PULLEY AND
BOLT. CAME LOOSE AGAIN EVEN LOCK TIGHT ON BOLT.
RUNNING 3.0 PULLEY ON DRIVE. HAS ANY BODY HAD THIS PROBLEM HOW DID YOU FIX IT. IS THERE A AFTER MARKET TORQUE CONVERTER AND PULLEY SETUP
THAT MIGHT WORK.
ANY HELP WOULD BE APPERICATED.
Old Mar 16, 2003 | 02:17 AM
1dirtyZ's Avatar
Default Re: PULLEY PROBLEM
what do you mean by pulley attatched to torque converter???
Old Mar 16, 2003 | 03:54 AM
Black LS1 T/A's Avatar
Moderator
First, typing all CAPS means you are shouting! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Do you mean the crank pulley... the pulley is bolted to the crank... not a "torque convert".
Read my post here:
ATI Procharger crank bolt cutting procedure
https://ls1tech.com/ubb/cgi-bin/ulti...=000108#000002
I also brought it to the top since I see some other ATI installs are going on, and someone may have this issue if they go above 450 RWHP and close to the same torque. At the very least,you guys doing the install, make sure the pins are in the best position and use Red Loctite or equivalent liberally on the bolt threads. Take it all the way to the specs the ATI procedure recommends... no fudging! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
For the ultimate, you could always key the crank.
