GMR SPEED twin turbo ......
#142
SSU Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
That's an interesting idea for the kit....where did you get the idea? ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Oh yeah...pssst....[see below]
Originally Posted by RyanJ on 11-02-2005, 03:19 PM
I say you use two THICK logs and brace the turbo's to the block. Put the turbo's where the A/C and Alt usually go. use a nice vertical flow bar and plate I/C. I'd also recommend getting with the guys that make that MAFT-Pro and maybe your timing will coincide and you can market that with it. A nice tough twin kit with SD tuning would be the BOMB.
#143
Guest
Posts: n/a
Originally Posted by Joel@GMRSPEED
We have the some hot parts done already. Were gonna have to work are butts off ,but I know a reasonable priced kit is needed for the f-body. Any good input would be great.
THanks Joel @GMR
THanks Joel @GMR
Thanks Joel@gmr
#144
why not go for more of a CAS design? It just puts the turbos in the opposite positions allowing you to retain everything? Plug changes are not impossible on the CAS setup. It limits you to the amount of turbo used but this is for a streetable kit and 1000 rwhp is not any where near practical for the street. BTW i am not ******* the kit in anyway as i am sure it will make power and looks very well packaged but it definitely wouldn't be for me. I am glad to see that a solid company is taking initiative on F body turbo kits. Are you guys interested in making something that would make less power and keep all accessories?
A lot of people have been having problems with relocating the alt. did you guys address this yet? Would A/C relocation be an option?
Kit looks great so far.
Greg
Greg
#145
Guest
Posts: n/a
Greg
Greg
The a/c bracket that we use is very good. We provide full detail on how to install it. It come almost all the way togther for you to install.
thanks Joel
#146
I think that makes perfect sense Joel. Guys who aren't hard core enough to lose the A/C can do your single kit and upgrade to a T76 good for 1000horse and the guys who want to go all out can do the twin kit with T61s or even T67s or so for big displacement. I don't think you can justify building another ls1 twin turbo kit due to the limited market but that is Just My Personal Opinion.
#147
Suspended Sponsor
We are releasing the price of the TT kit for the Ls1 f-body. It will include...
2- Precision T-61...that you can upgrade if needed
2- Tial 44mm WG
1-Tial 50mm BOV
304 stainless piping hot&cold
stainless steel t-clamps
4-ply 500deg silicone
Alt bracket
2-k&n air filters
3.5" bar&plate intercooler
MSD wires
DEI boot covers
All bolt&nuts and oil lines
Ready to install and tune, with supporting fuel system upgrade.
Optional boost controller e-boost2 $439.99 if purchased with kit.
Fuel system upgrade...$1249.99
Intro price for the first 10... $6699.99
2- Tial 44mm WG
1-Tial 50mm BOV
Alt bracket
2-k&n air filters
MSD wires
DEI boot covers
#148
SSU Moderator
Not bad. Not sure why shops insist on using 304 stainless when coated mild would work better AND be cheaper...but whatever. IMO, switch to mild steel, coat the logs, ditch the MSD wires unless you are using some custom setup length-wise, and offer it w/o turbo's...or at least with Master Power 60-1 or 62-1. Similar power with less cost. You could drop the whole kit a few bucks with those changes.
Actually, you know what you do? You make a wooden model of some cast logs and get them cast in bulk. The placement is right, the material is not. Won't be cheap, but people WILL pay for leak/crack/headache free manifolds.
#149
Originally Posted by tamanjd
it made 406 rwhp and 475 rwtq and we saw alittle more but it kept blowing through the tranny and converter. I also need valve springs as the boost is holding the open at high rpms. the car was completely stock and i need to get a stronger tranny for it before we put any more tune in it or the trans will be all over the shop. It is running awsome and works great and I coulnt ask for any more from the car especially with no supporting mods yet.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
