8-Rib for Procharger
Old Apr 8, 2003 | 10:40 PM
cgfirehawk's Avatar
Default 8-Rib for Procharger
Anyone know who makes or sells an 8-rib pulley set-up for Procharger kits on a F-body or Vette? Thanks in advance, Carl
Old Apr 8, 2003 | 10:43 PM
BIGBOS's Avatar
Default Re: 8-Rib for Procharger
I know ASP makes them I recently ordered a crank and blower pully from them, 8 rib
Old Apr 8, 2003 | 10:56 PM
cgfirehawk's Avatar
Cool, Thanks.
Old Apr 8, 2003 | 11:01 PM
scottywheels's Avatar
I run a 8 rib crank pulley from ASP 8.5 inches. I also have a 8 rib 4.25 from ati however I am getting a sponser from a company that is makeing pulleys for me and I will let you know how they turn out soon.
Old Apr 9, 2003 | 07:16 PM
cgfirehawk's Avatar
That would be great. I work at a Performance Shop here in Middle TN, and I have a few customers wanting an 8-rib setup for their f-bodies and vettes. If you could keep me up to date on how that is going I would appreciate it! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 15, 2003 | 02:57 PM
cgfirehawk's Avatar
ttt
Old Apr 17, 2003 | 10:13 AM
Well the 8 rib set up works. I have to get a gatorback belt but other then that it made 15 psi right off the bat no slip. call jimmy at reichard racing and he will set you up with what you need.
www.reichardracing.com
Old Apr 17, 2003 | 10:46 AM
cgfirehawk's Avatar
Cool man thanks for keeping me in mind. I like to use the gator back belts anyways so that works out. Hey man thanks for the hook-up and by the way did you key the crankshaft and balancer so it wouldn't slip with that high of boost or are you not seeing any slippage problems? Thanks again man! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Apr 18, 2003 | 12:09 AM
No problem, yeah cartek keys the crank and the pulleys.
