question about boost?
Old Apr 22, 2003 | 01:29 PM
vhgjk123's Avatar
Default question about boost?
On every board I go to the general consensus is when you supercharge you should only run 5lbs of boost on stock internals. However, when you turbocharge the safety zone is 7lbs. Whats the deal, why are there different numbers for those?
Old Apr 22, 2003 | 02:56 PM
Black LS1 T/A's Avatar
Moderator
Default Re: question about boost?
That may be true if they were comparing the Turbo to non-intercooled/non-aftercooled systems. Intercooling/aftercooling increases the boost you can run on a supercharger. Who runs a SC without inter/after cooling these days?
I'm not sure why these folk are saying what you are repeating... what is their rationale?
Old Apr 22, 2003 | 02:57 PM
smokinHawk's Avatar
Acutally ive noticed that people run more boost with a supercharger 9si while those with a turbocharger run around 7psi (pump gas)
approximatly with stock engine.
maybe cause the turbo produces a little more heat. but output can be the same.
Old Apr 22, 2003 | 03:33 PM
vhgjk123's Avatar
I think you answered my question. I was thinking about non intercooled superchargers. Thats why they are using less boost on stock bottom end/compression
Old Apr 22, 2003 | 03:46 PM
LS1Bird's Avatar
A supercharger without intercooling - NO THANKS!
I run 8 pounds intercooled on 91 octane. No complaints at all, and so far no engine troubles.
Mike M
