which FI motor is for me? help me decide!
I plan to run the whipple on either motor with about 10-15lbs of boost. I don't want to spend more than $7000 for the motor. Installation and tuning has already been worked out. What do you guys think? Any other suggestions are welcome.
a good fuel system is about 1500$
injectors
rails
braided hose
sumped tank
and a large truck
id look at a 408 with a turbo that would hit boost early... say 2000-2500 .... thats mucho weight to move around so you need alot of down low power...
or just spin the crap outa that maggie
The truck only pushed 360hp or so and the tuning was at 11-1 A/F. Some piston's just crap the bed early
It's a 50/50 shot hoping the stock piston's/stock rod bolt's will hold
I'm leaning toward the FFHP setup. I've gotten other quotes on complete 408's and their's is close to the best price, plus Brad seems like a cool guy. I know there are bigger names out there but they are all much more expensive. What if I bought the 402 shortblock from SDPC, WCCH heads, comp cam, arp head studs, used my stock rockers, pans, covers, manifold, tb, etc? Anyone have thoughts on that setup?
$3500 + 1300 + 350 + 250 + labor to put it all together and install it. I should be around $6000 right? before the fuel system upgrade if one is even needed
The truck rails are huge and hold lots of fuel
A simple Double pump intank setup will be enough to help feed 700rwhp
Parish and myself have them parish has seen 1000rwhp with it
On the motor I think i know someone who has somthing for sale..
It's all about the Benjamins.
