d1 @ 5 psi
Old Nov 13, 2005 | 01:59 PM
01superta's Avatar
Default d1 @ 5 psi
hey guys, new to superchargers, just bought a procharger d1sc , is it possible to run a d1 @ 5 psi, or is it only an 8 and above blower? btw my car is an 01 ta h/c, full bolt on stick, thanks
Old Nov 13, 2005 | 02:19 PM
Z8'S's Avatar
I am running a D1 on my Formula at 6 psi thru out a 1/4 mile pass.11.25 @121.3
Old Nov 13, 2005 | 03:38 PM
01superta's Avatar
thanks z8, that answers my ?
Old Nov 13, 2005 | 07:33 PM
EPP's Avatar
EPP
On a bone stock LS1, the ATI ProCharger D-1SC eight rib assembly with the 4.5" pulley, which is the largest one ATI makes, will produce somewhere around nine to ten pounds of boost. Add headers and a better flowing exhaust system, and the boost will drop down to somewhere in the eight psi range. Add a camshaft or a set of heads and you will see a further reduction. It sometimes takes a good educated guess on which blower pulley to supply a customer, for the desired boost that they want their supercharger to make. Bob
Old Nov 13, 2005 | 08:41 PM
Nickn20's Avatar
yea what he said, do heads and cam good way to drop boost.
BTW EPP I installed a D1SC kit you sold to a customer of mine with a ATI balancer and the bolt on 8 rib setup and the new bigger intercoolers, man what a fantastic setup that is! the car made 480 rwhp on my dynojet after I tuned it, bone stock car other than the ATI, even the catback was stock! boost was around 9-10.
Old Nov 13, 2005 | 08:58 PM
Chas1's Avatar
Mine was a 5 lb P1 with a stock car ran 381 rwhp and 368 rwtq. I just added the SDCE 8 rib, lt headers and 42 lb injectors. I'm at 7 lbs boost and 436 rwhp and 404 rwtq. What a big improvement.
Old Nov 14, 2005 | 01:43 AM
EPP's Avatar
EPP
Smile
I'm glad to hear everything went great! ATI ProCharger makes a great kit! Thanks for letting me know. Bob
Old Nov 14, 2005 | 01:25 PM
01superta's Avatar
I have stock lower end with 228/232dur 560/566lift 110lsa-cam patriot 5.3 stg 2 heads, slp lt's, ported tb, moser 12-bolt w/4.11, stock trans, spec stg 3 clutch, exhaust cutout-closed cutout runnin through dynomax muff. stock tips. what pulley would I need to reach 5 or 6 psi. on a d1 blower, thanks for all the info guys
Old Nov 14, 2005 | 01:47 PM
EPP's Avatar
EPP
With the 8 rib ATI ProCharger D-1SC, a pulley in the 4.0 size would probably get you to where you want to be. Your 110 lsa will bleed out a lot of the boost. Bob
Old Nov 14, 2005 | 02:02 PM
01superta's Avatar
thanks bob, you've been really helpful
Old Nov 14, 2005 | 02:06 PM
01superta's Avatar
also, will I be able to run my car after I install the kit? , I have a full dyno tune on my current setup, or will the car need to be tuned before I try to start it up?, even poor running, but still able to drive down the block will be ok, I work at livernois motorsports, and if needed I'd just drive it there right away for a tune. it's tuned for a 100 dry shot of juice right now, so dan millen from livernois didnt add full timing
Old Nov 14, 2005 | 04:59 PM
EPP's Avatar
EPP
I would leave your stock injectors in it until you get a tune, as it would run really rich. Just don't go wide open throttle under any circumstances!!!!!!!! I have had people drive half way across the country to bring their car to us to get a tune, with no ill affects. Bob
Old Nov 14, 2005 | 06:52 PM
01superta's Avatar
thanks again bob
Old Nov 14, 2005 | 08:00 PM
unit213's Avatar
Administrator
Originally Posted by 01superta
I work at livernois motorsports...
Why not just ask Dan? There aren't too many people more knowledgable
than Dan at this stuff.
You drive a red T/A by any chance?
Old Nov 15, 2005 | 02:56 PM
01superta's Avatar
yup, just didnt want to bother him, plus bob seems to know what he's talking about, but i'll talk to dan about it sooner or later, the sc wont be going in for a couple months
Old Nov 15, 2005 | 02:59 PM
01superta's Avatar
who are you unit?? cuz I'm at lvd not motorsports but I'm sure you know that already since you know my car
Old Nov 15, 2005 | 08:00 PM
SilverC5Vert's Avatar
01superta, I see you work at Livernois Vehicle Development... are you Derek? I work at Motorsports and I believe I talked to you at the Telegraph Cruise and in the shop when your car was on the dyno. Dan won't be bothered by your questions, just ask and I'm sure he'd be happy to help you out.
-Rick
Old Nov 15, 2005 | 10:37 PM
01superta's Avatar
thats me Rick,I dont post on here too often, usually my ?'s are asked by other people on here, I'll talk to dan when I'm closer to installing the sc,I'm gonna have him tune it again, see ya around the shop, D
