Turbo mounted an getting closer...AGAIN!!!
Old Nov 15, 2005 | 02:21 PM
black98ws6ta's Avatar
With the 5.3/6.0 manifolds is there room for a downpipe anywhere else other than between the block and the passenger side manifold?TIA
Old Nov 15, 2005 | 02:37 PM
V6 Bird's Avatar
Originally Posted by PurEvl
t88 with 6.0l manifolds
fuel system
intercooler
Didnt you have a STS setup before this? Looks good.
Old Nov 15, 2005 | 03:04 PM
smokinHawk's Avatar
it fits there best, especially as the exhaust runs on that side to the catback
you mihgt be abble to fit a 3" on the other side if your lucky, but you can fit up to a 5" DP through there if you convert to a solid mount, 4" if you use a poly mount.
Old Nov 15, 2005 | 03:08 PM
PurEvl's Avatar
yep, and after all the bs im going though...i wish i still had it Its coming together though. Your going similiar route to this right?
Old Nov 15, 2005 | 03:09 PM
PurEvl's Avatar
Originally Posted by black_z
What is the advantage of using a piece of flex pipe? Is it just to help avoid cracking from the torquing of the motor? Where are you placing the wastegate? If your using a stock Kmember, how much needed to be notched out?
i have bmr a arms upper an lower an bmr k member...nothing is notched..YET...if we go 4" DP there is some work to be down, smoking hawk has already done it to his
Old Nov 15, 2005 | 03:10 PM
V6 Bird's Avatar
In the end it will be well worth it man. And im doing a kit just dont know what size turbo yet. I cant decide if I want to run it within a set of rules or build it for me. If i build for me, its staying on the street with an A to W and a 88 or 91mm setup.
Old Nov 15, 2005 | 06:13 PM
onfire's Avatar
Coal Mining Director
Great looking set-up. The pump may be small for your goals though. I've talked to Jim Craig about my project and it's less hp than yours. Looks like a Weldon 600A rated for 60gph at 60psi....about 750 engine horsepower if you don't boost reference.
Might want to look at the 2015 or 2025. www.weldonpumps.com has the pump flow curves.
Old Nov 15, 2005 | 06:23 PM
J&J Speed Shop's Avatar
Nice looking alternator mount where did you get it from?
Old Nov 15, 2005 | 06:54 PM
Slowhawk's Avatar
LS1Tech Sponsor
Matter's how you look at it.We had a single intank 255 support his last setup which did 700rwhp and never missed a beat I'm sure this 600a will support 900rwhp easilly enough.
Old Nov 15, 2005 | 06:57 PM
frcefed98's Avatar
Nice, don't you hate having to do **** twice
When do you think it'll be able to fire up?
J
Old Nov 15, 2005 | 07:27 PM
69firebird's Avatar
that is a nice looking "TEMP" kit, hell it looks better than alot of others finished kits.
either route you go itll end up nice
Old Nov 15, 2005 | 07:49 PM
  #32
SPANKY LS1's Avatar
What kinda numbers are you looking for with the 408?
What is the turbo, a regular PT88? T4 or T6 flange?
Looks good, Shawn
Old Nov 15, 2005 | 08:41 PM
  #33
KAOS's Avatar
should be some nice numbers i would think. look at parish with his 408
Old Nov 15, 2005 | 09:42 PM
  #34
onfire's Avatar
Please share the magic as I'm currently rebuilding my fuel set-up now. If you don't boost reference and drop the base to 3bar and boost the voltage to 17v, a 600a only jumps to 85 gallons/hr....531lbs/hr....what else can you do...that's not enough for 900rwhp....could use two ....unless Jim under rates his pumps for safety.
Old Nov 16, 2005 | 04:24 AM
  #35
Slowhawk's Avatar
LS1Tech Sponsor
J
I'm thinking ,,never That way I have no hopes like we did before Made a bracket to support the Turbo last night.Took me 2 hours Today I'll do the altinator/belt setup so we can finish the downpipe.Then a custom t-stat housing,wastegate ect.
Old Nov 16, 2005 | 06:20 AM
  #36
TA2SLOW346's Avatar
How you going to route the lower radiator hose with everything in the way?
Old Nov 16, 2005 | 07:15 AM
  #37
Tiago's Avatar
easy to do, but alot of people dont' have the means to do it.
Old Nov 16, 2005 | 07:56 AM
  #38
Slowhawk's Avatar
LS1Tech Sponsor
That is the reason we made the piping the way we did.The 90 in the 3.5" pipe gives plenty of room to run a stainless pipe for the coolant.
Old Nov 16, 2005 | 09:28 AM
  #39
Cyborg's Avatar
Mike an AEM Anti-lag would be awfully fun on your setup
