Turbo mounted an getting closer...AGAIN!!!
Old Nov 15, 2005 | 08:19 AM
PurEvl's Avatar
Default Turbo mounted an getting closer...AGAIN!!!
t88 with 6.0l manifolds
fuel system
intercooler
Old Nov 15, 2005 | 08:28 AM
Tiago's Avatar
nice
Old Nov 15, 2005 | 08:39 AM
NA$TY-TA's Avatar
hmmmmm the only pic's i can see is of the fuel system....
Old Nov 15, 2005 | 08:47 AM
CHRISPY's Avatar
nice!!!
Old Nov 15, 2005 | 09:15 AM
Ping King's Avatar
hows the down pipe being routed?
Old Nov 15, 2005 | 09:21 AM
smokinHawk's Avatar
not to bad, i would have suggusted mounting it like mine though as it would have simplified the downpipe routing and coldpipe routing.
are you going through where the AC used to be for the downpipe? with a little grinding on the kmember, and block (old ac mounts) you can stuff a 4" through there.
Old Nov 15, 2005 | 09:28 AM
PurEvl's Avatar
yes i believe thats where he is going, but we are gonna use 3 1/2 I think. This is still most likely just a temp setup
Old Nov 15, 2005 | 10:04 AM
smokinHawk's Avatar
bah, why temp, just get it done then max it out to its limit.
Old Nov 15, 2005 | 10:48 AM
Josh@KY-Turbo's Avatar
very nice looking setup.
Old Nov 15, 2005 | 11:39 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice, what fuel pump setup you doing? Are you rigid mounting the turbo the frame rail there?
Old Nov 15, 2005 | 11:48 AM
PurEvl's Avatar
fuel pump is the nasty setup with the sumped tank....the turbo to my knowledge is going to be bracketed in place.
Old Nov 15, 2005 | 11:49 AM
PurEvl's Avatar
i know i know, but the 4400 for the other kit is a waste otherwise...I will see how it comes out, its all getting coated an blinged out too, either way one of them will be sold. I do want my ac back though.
Old Nov 15, 2005 | 11:50 AM
LS1Tech Co-Founder
Sorry, I mean what size fuel pump.
Old Nov 15, 2005 | 11:58 AM
Brandon Boomhauer's Avatar
how is the cold piping going to be routed??
Old Nov 15, 2005 | 12:44 PM
Slowhawk's Avatar
LS1Tech Sponsor
I'm kind of playing on this setup to see how it goes.The Turbo is being supported off the motor but you really can't see that bracket.The downpipe should be done today/tomorrow but I have a ton of room to make it.
Whne this is done we will push it to the limit's to see what king of power it can produce and then I'll think about doing more (Jigged and Tig'd).
Old Nov 15, 2005 | 12:46 PM
Slowhawk's Avatar
LS1Tech Sponsor
Thats already done from before.The turbo right now is just pointing up till I cut out the frame ect.
Old Nov 15, 2005 | 12:58 PM
LSONE's Avatar
is that fuel rail/line seup the nasty one?
Old Nov 15, 2005 | 01:17 PM
PurEvl's Avatar
yes all the fuel components are from nasty....
Old Nov 15, 2005 | 01:26 PM
LSONE's Avatar
very nice, I'm ordering his system on friday
Old Nov 15, 2005 | 01:40 PM
black_z's Avatar
What is the advantage of using a piece of flex pipe? Is it just to help avoid cracking from the torquing of the motor? Where are you placing the wastegate? If your using a stock Kmember, how much needed to be notched out?
