STS turbo
Old Nov 20, 2005 | 10:34 PM
nyg215's Avatar
Default STS turbo
im looking into gettin the STS turbo kit. with my current mods and with a set of afr 225cc heads what kind of number would i be looking at????
Old Nov 20, 2005 | 11:00 PM
kolkid's Avatar
depends on how much boost u ganna be running
Old Nov 21, 2005 | 12:30 AM
TeeKay's Avatar
Cam looks a little too big for turbo apps. It has +4° of overlap which can kill the boost/allow reversion. A wider LSA with a negative overlap is generally recommended. For instance a 224/114 cam has a -4° overlap. A lot of folks who know say use the Z06 cam for good results on the cheap. I can't remember the exact specs, but it's like 206 to 210 on 114 to 115. Slightly different year-to-year. That's a very general remark. Check with the turbo gurus for a better read.
BTW, I read that the AFR 225 were designed for larger displacements, and the 205's were more for the stock displacement. Here again, check it out before you take my word alone. HTH
Old Nov 21, 2005 | 06:21 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com...Car.php?car=32
Check out the STS Camaro SS we put together above. Bob
