Custom supercharger mounting brackets?
Old Nov 24, 2005 | 07:54 PM
Lawnboy's Avatar
Restricted User
Default Custom supercharger mounting brackets?
Who makes , or would be interested in making - fabing up mounting brackets to be able to install a Paxton Novi 2000 on a LS1 F-body car.
Please let me know
thank you
Old Nov 25, 2005 | 07:53 AM
01red28's Avatar
well if you know whatDimensions you wont it I might be able to help you?
here are some pics of some tips i just made could not find any 3inch tips that were like stock so I had to make them they are polished stainless only 3 seams that had to be tig welded
Attached Thumbnails Custom supercharger mounting brackets?-dcp_1547-ty.jpg   Custom supercharger mounting brackets?-dcp_1548-ty.jpg
Old Nov 25, 2005 | 01:27 PM
METAL MAN's Avatar
I can do it if you send me a template or if you're close to Phoenix bring the car and blower unit to me.
Old Dec 7, 2005 | 11:50 PM
Lawnboy's Avatar
Restricted User
anyone interested in making me a mounting bracket like the powerdyne bracket, it mounts the supercharger so the cars stock 6 rib acessary spins the supercharger.
Powerdyne.com click on installation manual then 98-01 LS1 (bracket Pictures there)
Paxtonauto.com click on novi 2000 and 2000RR (novie pictures there)
Old Dec 8, 2005 | 12:01 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If I made something custom, I would use 8 rib, 10 rib, 12 rib or cog solutions.
What power you looking to make? I've hit 17-21 psi.
Old Dec 8, 2005 | 08:03 AM
boosted99camaro's Avatar
I agree if you try to mound it like the powerdyne you will get major belt slip with the novi unit.also the novi2000 is lubercated by your engine so you will need a return line and if you mount it low like that you will have oil return problems.you will have to mount it like the vortech setup and thats going to be a lot of work!
if I were you I would have got the procharger dsc1 kit.that headunit is vary simular to the novi 2000 and it bolts right up!
Old Dec 8, 2005 | 08:07 AM
Lawnboy's Avatar
Restricted User
i just recieved my procharger -LS1 mounting bracket, I decided to mount it where the procharger would mount
Old Dec 8, 2005 | 08:15 AM
I think thats still going to be to low for proper oil drainback.
Old Dec 8, 2005 | 08:24 AM
Lawnboy's Avatar
Restricted User
i can run a scavance oil return pump like STS does , with there rear mounted turbo kit.
and have the oil routed to a frount mount rail oil cooler befor it returnes to the motor.
Getting the oil back to the engine wont be that much of a problem, I do not want to mount it high like Vortech does., but if i realy have to i will.
