Best Oil Catch Can/tank?????
Old Dec 4, 2005 | 05:14 PM
nitrorocket's Avatar
Default Best Oil Catch Can/tank?????
I need a oil catch can. I would prefer one without the breather on top. Who has had good results with a good one. I am looking for one that 0 oil can get past. I cannot have oil in the intake.
Please let me know, I need to buy one ASAP! Thanks.
Old Dec 4, 2005 | 06:27 PM
Assassin's Avatar
venting the valve covers and pluging the intake will take care of any chance of oil getting in there... nothing is 100% filtration!!!, and if you run a check valve its just going to make the crankcase pressure waaaaay higher under boost cause it will totally choke it off...
here's what I'm useing https://ls1tech.com/forums/forced-induction/398599-pvc-pcv.html
Old Dec 4, 2005 | 06:31 PM
Blown Ta's Avatar
i have the greddy can, works good. but i've been looking at the amw one, until i saw the price.
Old Dec 4, 2005 | 06:32 PM
Right now I just run 2 breathers with no pcv. I just installed an LS6 valley cover with the pcv built in.
During long drives, I get slight smoke seeping out from under my hood at idle. I can't stand the smell. Being that I have just a street car, I want it to be smokless! I would sure hate to run 2 catch cans, that could get crowded and expensive!
I just need to find a 100% catch can, somebody has to make one?
Old Dec 5, 2005 | 01:55 PM
firehawk123's Avatar
The AMW is the one you are looking for.i have one i my car and its working good.
Old Dec 5, 2005 | 06:02 PM
Does any oil get by it? Have you checked the hose comeing back from it? Is there any oil residue?? Let me know. Thanks.
Old Dec 5, 2005 | 07:30 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
i just have a moroso can from the valve cover and nothing to the intake
Old Dec 5, 2005 | 09:48 PM
Lawnboy's Avatar
Restricted User
is there a web sight for the AMW?
And what is a LS6 valley cover?
I amount to get boost from a Novi 2000 on my 01 SS,
I am looking into things i am going to need for the supercharger
Old Dec 6, 2005 | 05:07 AM
SidewaysTA's Avatar
AMW is a sponsor. --------------->
Old Dec 7, 2005 | 04:41 PM
I just cannot afford to get oil into the intake at all!
I will have to check out the Moroso unit.
An Ls6 valley cover is different then the ls1 in that it has the pvc breather in the cover. I did it for my application to keep visible hoses to a minimum.
Old Dec 7, 2005 | 04:59 PM
UnderPSI's Avatar
The Moroso one is nice. Call clint at C&S in butler. He can get you one. 781-0469
Old Dec 7, 2005 | 05:20 PM
Blown Ta's Avatar
hers's another one i found.
http://www.mckinneyraceworks.com/CatchCanInfo.html
Old Dec 7, 2005 | 06:24 PM
LTLHOMER's Avatar
MOR-85465 and weld on another -10 male fitting and run one from each v/c. That's how mine is. Have it tucked up under the passenger front wheel well.
Old Dec 13, 2005 | 05:21 PM
Does anyone know how the AMW works internally compared to :
The Mckinney looks like the best I have seen.
