Comp 206/212 for turbo truck...
Comp 206/212 112 for turbo truck...
Like it says.. I'm thinking the conservative cam will help lower the spool point and be better for the way the truck will be used. I am deliberately looking for a big fat wide powerband and the ability to use a non stall converter... Milage cruising with the boost gauge at zero will be respectable too...
With a cam that small I dont need a wide LSA.... I'm pretty sure its going to do the job.. But its looking like at that short duration a TIGHTER LSA is better.
With two turbos selected for a quick spool + the right cam and a 6.0.... EAPro tells me its going to be a low rpm tq monster...
Good across the board really... Yes a bigger turbo friendly cam would be more power up top but lack the card table shaped Tq curve...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by Exotic Performance Plus
I'd shoot for a 114-115 LSA camshaft, so you're not losing precious boost through the overlap. Bob
There is no overlap on that camshaft.
If I found a cam or had one ground the same but at 110 it would still be or close to 0 overlap.. Its a small duration cam plus a split pattern... Its fine at a tighter LSA
Valve Timing At 0.006
Intake
Open 20
Close 59
Exhaust
Open 67
Close 18
http://www.compcams.com/Technical/Se...mber=54-408-11
