Turbo Carnage (pics)
According to what class you run, boost levels can reach the 270psi range using 4 turbo's to compund the boost on diesels. Alcohol tractors run a lot less boost, 70psi range. It's a fabrication nightmare running the tubing on a 3 or 4 charger system.
JZ
right click and save as...outlaw truck
stock truck class....right click and save as
Jose
Listen to the ricers.
Ahahah
Well unfortunately you can't run a BOV on a diesel since you have no vacuum
, unless its electronically controlled.
Yea...straight alcohol and about 100lbs...my neighbor has one and he runs straight alcohol and about 115lbs...and let me tell you that mother ****** moves...hes going about 30mph down the track...
How the hell do you tuner those things??
Needeless to say thats and expensive sport...
john
john
JZ
