which makes more power?
Old Dec 15, 2005 | 06:17 AM
DanaliHD's Avatar
Default which makes more power?
which FI setup will make more power:
Livernois turbo with upgraded headunit (76mm)
OR
Procharger F1R?
Let's assume the cost exactly the same, which is gonna lay down more power to the wheels and which is better for a daily driver?
Old Dec 15, 2005 | 08:18 AM
300bhp/ton's Avatar
What's the question?
A DD is not going to be ideal for MAXIMUM power. But there again MAXIMUM power is also not ideal as a DD.
A turbo system has the ability to always produce more power, this is because there is less loss with an exhaust gas driven turbine than wilth a belt driven one.
If you are wanting a good setup, maybe clarifiy the use/application and the cost. This will then dictate what is possible and appropriate.
Old Dec 15, 2005 | 01:07 PM
DanaliHD's Avatar
I just figured out what DD means. that one took me a minute. lol. The use is bad *** daily driver that runs faster than any other 6000+lb vehicle at the track. I'm thinking low 11's would be spectacular.
Old Dec 15, 2005 | 01:33 PM
ABeasst's Avatar
I'd go with a turbo that way you can turn it down when just riding around. This means less stress on the motor. If you run a F1 its gonna be making that power ALL the time and putting a lot more stress on the motor since you cant just turn a *** to get the power you want.
Old Dec 16, 2005 | 06:21 AM
300bhp/ton's Avatar
Yes I agree, the modern ECU controlled turbo setups are very capable. And can be easily controlled. However, most poeple will probably leave it on the high setting and I know several people who just couldn't resist the temptation in turing up the boost a little bit more, then just a tad more and then BANG!
Ultimatley a turbo setup should produce the most power. But for a street car power delivery is in many ways more important.
Also a turbo setup will eaily cost more in time, money and R&D.
IMO I'd always go for a postive displacement supercharger. They can easily produce enough power to blow the engine up and cause the need for upgraded drivetrain components.
So if you are after a fast drivable street setup I really don't think you can go wrong with a PD blower.
But for some there is the exotic allure of turbochargers. Which is why they will defend them until death claiming there are the best at every thing, including making toast and pinting the house.
Best bet is to keep an open mind and research, and see which setup offers the BEST, realistically the BEST benefits for your requirements.
Old Dec 17, 2005 | 01:27 PM
unit213's Avatar
Administrator
Have you ever even had a positive displacement blower?
Old Dec 17, 2005 | 01:39 PM
V8_DSM_V8again's Avatar
Turbo it.
I'm trying to get the short box into the low 4,000# range..... Fiberglass fenders, bed sides and alot of weight reduction.. The IFS will have aluminum ford 8.8 pumpkin from IRS with IFS gears in it. I was thinking of a 203/205 double low tcase but it would weight 240#... So I'll use a modified Dana 300.....
I should be able to get close in weight...
Old Dec 17, 2005 | 03:28 PM
ddnspider's Avatar
id go Turbo.No parasitic hp loss from crank.Change boost with a **** and have different boost settings.Much better daily driver,low boost for cruising around town,high boost to try and pull your 11sec time slip.Ull need the torque from a turbo to get that big truck moving too.
Old Dec 17, 2005 | 03:35 PM
LSONE's Avatar
probably not, but he knows everything- so don't question him.
Old Dec 18, 2005 | 11:46 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
OR
Procharger F1R?
Will depend on the size of the engine and which 76mm unit it is. Answer those 2 questions and then we can go from there.
Jose
Old Dec 18, 2005 | 05:59 PM
DanaliHD's Avatar
sorry, i didn't realize i forgot to mention this will be on a 408 from LME.
no idea which 76mm turbo livernois uses. sorry.
Old Dec 18, 2005 | 07:45 PM
Wet 1's Avatar
I would imagine the F1R could pull higher peak numbers then the 76mm turbo (but it depends on the turbo in question).
Old Dec 19, 2005 | 10:56 AM
300bhp/ton's Avatar
Never owned one. But been in many. But I won't be getting one for the Z28 as they don't fit under the cowl.
