Progress Pictures...
Old Dec 21, 2005 | 10:36 AM
Ryan K's Avatar
Pathological Modifier
Once it was tapped into the pan, I cut it down from the inside.
The motor is in the car now. It should be running again by Friday!
Ryan
Old Dec 21, 2005 | 11:52 AM
00turboT/A's Avatar
Hey ryan setup looks great. Can you post up a picture on the old log manafold and the new modo where I can see the differance?Also what kind of coating is that? Is that also the upgraded t-76 from TTI? When do you plan on getting some numbers and dynoed?
Old Dec 21, 2005 | 12:26 PM
Ryan K's Avatar
The difference is in the size of the log and the size of the primaries. The old log also was heat cut flange, and was poorly aligned with the exhaust ports. All of TTi's kits now use the better flange. The coating is a Satin high temp coating from one of the coaters in my area, we'll see how it holds up before I give it away.
The Turbo is TTi's Hybrid T-76 (uses a smaller compressor housing to clear the frame).
I'll have numbers as soon as its running!
Ryan
Old Dec 21, 2005 | 09:19 PM
00turboT/A's Avatar
Ryan
Can't wait to see some numbers.
Old Dec 22, 2005 | 07:54 AM
RealQuick's Avatar
Sounds good!
Old Jan 2, 2006 | 12:20 AM
00turboT/A's Avatar
Ryan
Hey ryan any dyno number yet? Can't wait to hear and update
Old Jan 2, 2006 | 01:56 AM
Ryan K's Avatar
Right now I am waiting for my brake upgrade to show up, its ready to take down to the dyno...
Ryan
Old Jan 2, 2006 | 08:30 AM
sparkwirez06's Avatar
is that the location of the wastegate on the other setup? wouldn't it just vent the right bank? in process of builing a set up and looking for what works. THANKS
Old Jan 2, 2006 | 10:12 AM
GrahamHill's Avatar
That looks great! Got me droolin for sure and I like the simplicity look of the setup.
Old Jan 4, 2006 | 12:23 PM
Billiumss's Avatar
Nice!
Any dyno numbers with the stock block and TTI intercooler?
Old Jan 4, 2006 | 12:25 PM
NA$TY-TA's Avatar
Ryan
What brakes you going with???
Old Jan 4, 2006 | 12:49 PM
  #32
Ryan K's Avatar
I am going with Wilwood 13" 6-Piston Fronts and Wilwood 12" 4-Piston rears... Shouls be a nice setup, but limits the front wheel options.
Ryan
Old Jan 4, 2006 | 01:08 PM
  #33
StoleIt's Avatar
NKAWTG...N
have you ever had any problems with burning oil Ryan? My return is in the same spot but mine will crop dust whenever i let off the throttle at mid-high rpm. I'm trying to figure out of its the return, blowby, or if its getting too much oil in the first place. do you have a restrictor somewhere in your oil feed line?
Old Jan 4, 2006 | 01:12 PM
  #34
Ryan K's Avatar
If it crop dusts when you let off, its not the oil return, You are most likely sucking it into the intake...
Ryan
Old Jan 4, 2006 | 01:18 PM
  #35
RyanJ's Avatar
SSU Moderator
I never really noticed, but why wouldnt TTi put the x-over pipe forward more in that notch of the oil pan...wouldnt that give a little more clearance? I never looked while thinking about it...would it matter? Would that clear the K and everything?
Old Jan 4, 2006 | 01:20 PM
  #36
Ryan K's Avatar
The stock K-member fits there, the cross over would not fit there.
Ryan
Old Jan 4, 2006 | 01:48 PM
  #37
StoleIt's Avatar
NKAWTG...N
Ryan
Hmm so most likely to much oil pressure then? Fun fun, guess I gotta find me a restrictor.
Gratzi
Old Jan 4, 2006 | 01:57 PM
  #38
Ryan K's Avatar
Gratzi
Actually, I'd look into the PCV system... or the valve seals. How many miles on the motor? How exactly is your PCV system routed/connected? When you let off, you create a very high vacuum in the intake manifold, and the chances are that you draw oil into the cylenders from leakage by the intake valve guides or the PCV system.
Ryan
Old Jan 4, 2006 | 02:04 PM
  #39
StoleIt's Avatar
NKAWTG...N
Motor is stock with 6k on the clock. I believe I took the PCV system out when I installed the kit.
Old Jan 4, 2006 | 07:37 PM
  #40
smokinHawk's Avatar
putting the oil return on the side wont hurt, and easy to do when the engine is out
