It runs
Old Dec 17, 2005 | 03:25 PM
Slowhawk's Avatar
LS1Tech Sponsor
Thumbs up It runs
Started up PurEvl's car today and went to a nice 800rpm,18" of vacuum Car is pretty quiet with 2 bullet muffler's.No leaks in any welds or oil lines.Now I just got to take apart the intercooler piping,paint it and redo the coolant lines a better way.
So a few notes
1- Drilling the oil pan is no problem on the car.Took me 5 minutes to drill/tap the pan and the grease caught about 98% of the filings.
2-The stock fans fit no problem
3-This took forever
Link to idle video- This was on first startup after it sat for 4+ months so the lifter's are noisy
http://video.ls1tech.com/player.aspx...E-2D6B8951648F
Old Dec 17, 2005 | 03:33 PM
ddnspider's Avatar
SWEET!get a vid or sound clip Don!im curious how quiet is your definition of quiet
Old Dec 17, 2005 | 03:53 PM
Slowhawk's Avatar
LS1Tech Sponsor
I would figure a stock car with a flowmaster or so. Not bad for a 408ci setup,but I'm sure it will get loud under boost
Old Dec 17, 2005 | 04:04 PM
black98ws6ta's Avatar
So a few notes
3-This took forever
Sorry for not knowing about the set-up, but what cercumstance's do the stock fans fit? Assuming you moved the radiator?
Old Dec 17, 2005 | 04:15 PM
Hi Volume's Avatar
fabbing a custom turbo setup is ALWAYS time consuming as all hell... always worth the hard work and effort in the end tho! (provided you dont suck at it, haha)
Old Dec 17, 2005 | 05:43 PM
NA$TY-TA's Avatar
Pic's Don Pic's you know better then that
Awsome...
Kyle
Old Dec 17, 2005 | 10:57 PM
frcefed98's Avatar
Yikes you guys beat me to it, better get cracking on finishing mine up Can't wait to see some video of it on the dyno
Old Dec 18, 2005 | 06:43 AM
Slowhawk's Avatar
LS1Tech Sponsor
LOL,no rush,there is snow all over the place.
Old Dec 18, 2005 | 07:54 AM
KAOS's Avatar
this is with the tubular header setup? awesome. so everything fit right? cant wait to see how it turns out
Old Dec 18, 2005 | 08:08 AM
HellRaiser's Avatar
KAOS it was the Phamspeed tubular setup but those guys ditched it because there was to many issue's and they weren't being fixed, so the went with the truck manifold setup.
Slowhawk this car should make big power can't wait to see the numbers. PurEvl must be happy as hell its almost done.
Old Dec 18, 2005 | 09:20 AM
EPP's Avatar
EPP
Question
I'm glad to see another project from hell coming to an end! What is it with these turbo companies! I'd like to see Edelbrock or another large company come up with one, just like Edelbrock did for the Honda's. Bob
Old Dec 18, 2005 | 10:31 AM
Dr.x's Avatar
slowhawk what are you using to paint the piping? I was wondering If I could powdercoat the piping or would I have to get them coated.
Old Dec 18, 2005 | 10:36 AM
Inspector12's Avatar
TT-TECH Veteran
The charge pipes could be powder coated, but all the hot parts will need to be HPC/Jet hot coated.
Old Dec 18, 2005 | 07:43 PM
Slowhawk's Avatar
LS1Tech Sponsor
updated post with idle video
Old Dec 18, 2005 | 07:45 PM
V8_DSM_V8again's Avatar
Its not working.
Not mad just a heads up..
Old Dec 18, 2005 | 08:06 PM
Slowhawk's Avatar
LS1Tech Sponsor
Now it does.
Old Dec 18, 2005 | 08:10 PM
What do you have for engine mgt...
Looks like a clean install btw...
You will like the MAF in blow thru..
Old Dec 18, 2005 | 09:01 PM
Slowhawk's Avatar
LS1Tech Sponsor
Stock computer,MA ect. The car has a wideband and thats about it.I prefer the MA as blow through and we convert alot of Vortech kit's to work like that.
The plan is to run it on the dyno and see how quickly we run out of injector (old 60lber's) and go from there.Possibly switching to 96lber's and a BS3.
Old Dec 18, 2005 | 09:09 PM
ddnspider's Avatar
thankyou don!sounds good for a 1000+hp car
Old Dec 18, 2005 | 09:17 PM
The BS3 is worth it just for the closed loop WB....
It will idle alot better too.. The standalone can better control large injectors for a happier idle..
A GM MAF on a mass airflow translator was one of my favorite DSM mods...
Our stock sensor goes oh sh8t when a big enough turbo is installed..
