Phamspeed Install
Old Dec 19, 2005 | 03:26 PM
REDTURBOSS's Avatar
Default Phamspeed Install
I really need some help installing this kit? I am an idiot when it comes for stuff like this. It seems simple but dont want to risk anything. I need pics and stuff like that of past installs if possible???? I am just trying to get this all over with before I start school this winter. Does anyone know a cheap installer in the la area???
REDTURBOSS's Avatar
THe older phamspeed threats are locked. I really need help guys????
Old Dec 19, 2005 | 03:28 PM
KraZy's Avatar
Which kit did you get?
Old Dec 19, 2005 | 03:30 PM
ddnspider's Avatar
Just search Hellraiser and Frcefed98 and phamspeed because theres has been a couple documented installs.That should get you most of the way there then just post up a specific question and we'll help you out.Its pretty simple,take off the exhaust and headers and airbox and fans etc and tap the oil pan with it either on or off the car(search that) and then bolt on the headers and turbo and run the lines and your good to go.
Old Dec 19, 2005 | 03:32 PM
ddnspider's Avatar
delete your other thread and ill answer that question here.If you have the phamspeed budget kit which you prolli do,they said youll have to get new fans because there isnt enough room because of where the turbo sits.just hop on summitracing.com and get the FLX-240's theyre like $250 shipped.
Old Dec 19, 2005 | 09:07 PM
HellRaiser's Avatar
Pretty straight forward install. You really just have to jump in there and start working then you start to get a ideal on how everything goes.
Old Dec 19, 2005 | 09:15 PM
frcefed98's Avatar
MSD spark plug wires....
Old Dec 19, 2005 | 09:27 PM
SELLSZ06's Avatar
where in L.A r u? I installed mine myself, it pretty straight forward, if you have questions post and there about 4 guys here that have that kit and can help you.
Old Dec 19, 2005 | 10:26 PM
REDTURBOSS's Avatar
I live like 20 minutes from the LAX. It just seems like there are a couple of expensive mistakes that I can make with the kit thats all.
