Piston compression height
Old Dec 25, 2005 | 04:45 PM
TchargedLS1TA's Avatar
Default Piston compression height
What compression height on your pistons do you guys normally run with the 408+ cubic inch forced induction engines? Im lloking to be throwing about 19-25 psi of boost with maybe a squirt of nitrous for holeshot only... Is 1.125" sufficient?
Old Dec 25, 2005 | 06:07 PM
stevewix's Avatar
compression height is a component of stroke, deck height, rod length, and the amount you want the piston 'out of the hole'. if you have all of this other info i can help you out...
Old Dec 25, 2005 | 06:10 PM
stevewix's Avatar
http://www.diamondracing.net/cocalc.htm
btw this is really nice, and FYI my pistons for my 370 were a 24cc dish. hope this helps!
Old Dec 25, 2005 | 06:58 PM
SStrokerAce's Avatar
I wouldnt think it's enough unless the pistons are made specifically for that application.
Bret
Old Dec 25, 2005 | 10:54 PM
They are -30cc dished pistons with .107" valve reliefs cut in them..
Old Dec 26, 2005 | 09:37 AM
KCS's Avatar
KCS
Moderator
For most F/I setups you really don't want anything below a 1.250" C/H. Most shelf pistons are in the 1.300"s anyways. Just make sure that you have enough quench so that you don't smash the pistons into the head.
