What head gasket to go with for HIGH boost???
I ran this combo all season on one set of gaskets.
At the end of the season I was up to 27psi max at 21 timing. They leak no water. I do push some water on each pass but this seams to be the norm at this level. Thing is they could have stayed in longer but wanted to check things out and start fresh before going to Florida. I'm just telling you what has worked for me. Will it work for you? I don't know. But this is the same setup we will be using on the Formula when we replace the iron block. Cheaper then copper and no silicone mess to deal with.
Good luck.
The head and block prep is the same as for a MLS gasket... There are alot of these gaskets out in race engines now with awesome results.. They may be new but they work.
