heads 4 FI
Old Dec 27, 2005 | 01:27 PM
HAMRHEAD's Avatar
Default heads 4 FI
I was hoping to get some input on what to look for or any suggestions on heads for my future set up. It is a t-88 turbo on a iron race prepped block, 370-408ci. Not sure what to be looking for in a set of heads for this set up. Money isn't a real issue but nothing exotic either like $8000.00 dollars or anything. Just some suggestions. Thanks!
Old Dec 27, 2005 | 02:40 PM
98turbls1's Avatar
I'm running into the same kind of problem here...I think that I'm going to probably go with the good ole 225cc AFR's...You can get them race ported and stuff...Just depending how far you want to go but they will handle the boost definitely...Or you can look at some ET's...They go even further than the AFR's but if you want a little bit of good street manners then I wouldn't probably go any bigger than the 225s...Just my two cents cuz right now I'm in the same boat..What are your power goals??
Old Dec 27, 2005 | 03:43 PM
BLk01SS's Avatar
Those Livernois stage III heads might not be a bad choice if you looking to save a buck. Otherwise, you can't go wrong with AFR's
Old Dec 27, 2005 | 04:01 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd go aftermarket, and go ET Performance. They have a 240cc head that has a 800 thou deck (300 for stock). That's what I am planning to run in a month.
Old Dec 28, 2005 | 01:37 AM
HAMRHEAD's Avatar
I was leaning toward the AFR's and the ET's. But wasn't sure which. I'm having speed do the setup and will be looking at 900rwhp on race fuel. I was actually set on the AFR's until I saw Speed offered the ET's. Not sure which option to go with though. I will as always seek the advice of Speed but wanted to get an idea of what all the guys here thought as well.
Old Dec 28, 2005 | 07:05 AM
Blown408's Avatar
Customer service from ET is outstanding in my experience. I have emailed and called Cary at ET several times to ask questions (before and after I got my heads) and he was very helpful and prompt about responding. You can't go wrong with ET Performance!
Old Dec 28, 2005 | 09:08 AM
SINISTER's Avatar
fill me in anyone have a link to these et heads??
800 deck! sounding good.
im just running some 6.0 right now with dual valve spigngs and ti retainers and such..
Old Dec 28, 2005 | 09:56 AM
LS1Tech Co-Founder
www.etheads.com
Old Dec 28, 2005 | 10:07 AM
Yellowsierra's Avatar
I guessing these are 11deg heads so wouldnt you have to get a custom intake made? Im sure it would be worth it.
Old Dec 28, 2005 | 10:09 AM
LS1Tech Co-Founder
No, those ones do not require custom intakes.
Old Dec 28, 2005 | 10:16 AM
Are they 11 deg heads?
Old Dec 28, 2005 | 10:25 AM
LS1Tech Co-Founder
craig@etheads.com
Old Dec 28, 2005 | 06:21 PM
422 ragtop's Avatar
I am 99% on using the ET 265 11 degree, 72 CC chamber on a 4.125 bore standard stroke TT with the GMPP single plane, looking to make 1000 at the tires. The 860 deck and huge spring pockets (1.60 I think) should make them ideal for big boost.
Has anyone had these on a dyno yet or independent flow bench? The numbers on there web site are huge.
Attached Thumbnails heads 4 FI-copy-et-265-2-.jpg   heads 4 FI-copy-et-265-3-.jpg
Old Dec 29, 2005 | 06:02 AM
Blown408's Avatar
Mine were flowed at Force Fed High Performance on their bench
ET 225's
File Type: doc
Old Dec 29, 2005 | 09:25 AM
HAMRHEAD's Avatar
the ET's seem to be the way to go!
Old Dec 29, 2005 | 10:00 AM
turbo'd stang's Avatar
I'm building a similar setup..396 with an 88. I have a set of the 240 ET heads on order. If you can stand the wait, I would get them. For the money, it's an awesome head.
Old Dec 30, 2005 | 09:51 AM
HAMRHEAD's Avatar
The wait won't be a problem since they will sit at home till I come home in July anyway. I think these are the heads I'm going with. They sound pretty solid and have gotten a lot of thumbs up on them. Thanks guys!
Old Dec 30, 2005 | 04:39 PM
DanaliHD's Avatar
yeah, the wait on the ET heads is killing me. I've been waiting about a month now. I too went with ET 240s for my 408 FI setup
Old Dec 30, 2005 | 05:30 PM
I ordered mine at the end of Sept and have yet to get them, so be prepared for a little while longer
Old Jan 2, 2006 | 09:17 PM
DanaliHD's Avatar
WOW, that's just stupid. I'll jsut get something else if it's gonna be that long. Again, WOW.
