Is installing the Procharger also a good time to install a pulley?
The only install I am familiar with is the GTO, the procharger pulley has 3 pins that contact the OEM pulley webing. I went with an aftermarket fluidampr which allowed for a different procharger pulley that is bolted to the fluidampr.
In either case you must drill and pin the pulley to the crankshaft. the only question I would have is will the procharger pulley bolt up to what ever underdrive pulley you want to use????
Best bet would be to call Procharger and see what they say. Also I think Bob at EPP would know as well.
The ASP will not work for your application. Bob
