I love my LT1
Chris
ps I am in raleigh are near here or just visiting for the tune at CAM?
Type: 383 LT1
Block: LT1 4 stud main
Oiling: Melling HV Oil Pump, Canton 7 qt Road Race pan
Crankshaft: 4340 3.75" Eagle
Connecting Rods: 4340 5.7" Eagle
Pistons: SRP low compression
Cylinder Heads: LT4 castings reworked by Lloyd Elliot/ 2.08/1.60 valves
Camshaft: 224 /236 .606/.628 with 1.6
Rocker Arms: Comp Cams Pro Mag 1.6
Intake Manifold: LT4 reworked by Lloyd Elliot
Induction: ATI Procharger P-1Sc @ 8lbs
Ignition/Computer: Computer tuned by Jeff Creech/ Mallory HY-Fire 685
Headers: Pacesetter LT's
Exhaust: Borla
Cooling System: Factory except for CSI EWP
Fuel System: Msd 50# injectors/ Racetronix plug and play system/ Aeromotive adj FPP/ 2nd intank 255 lph pump/ Alky Control Methanol Kit
Thanks evryone. I live in Newport which is on the coast but I spend all my time in Jacksonville
I just helped with a turbo project for a friend if mine up here. He put a t70 on an LS1 and I cant wait to see what that sick thing will do
.BTW you made that power at 8lbs of boost through what type of intercooler, and don't they have a mustang dyno???? Either way badass numbers LOVE the TORQUE. Gotta Graph. I figured My buildup would net me about 550-600RWHP in the 8-10lb range plan on having it from 8-14lbs of boost.
. The p1 will hopfully make adequete boost for me (as much as I need anyways).What type of Dyno was that on, I seen the graph over at camaroZ28.com but don't recall if it was a Dynojet (even though it prolly said, LOL)
What intercooler setup you running, Twin High Flows, 3 core?????
I have the twin 3.5" intercoolers
