new sts turbo kit
5PSI you'll probably be around 420rwhp.
(btw you should hear my turbo spool up.....I had it out at Jerseys' saturday)
http://www.rceng.com/technical.htm#WORKSHEET
Figure 85% duty cycle and .6 BSFC. If the 353 dyno is your baseline, you should be comfortably above 450 whp on 5 psi. So figure about 550 crank hp that the new injectors will have to feed.
918 springs and hardened pushrods are a good idea! So is meth injection or IC for anything above 5 psi. HTH
BTW .....KEV, I wish I could have been there to see the beast.....how is your new set up working out for you......and how does it feel power wise????
I havent gone over 3k rpms. I am still running the procharger tune, as soon as work cools down it will be tuned.
The Camaro SS above may give you some ideas. Bob
if yah can! Make sure they are on tight~!
while tightening invision you met a really hot hooker in amsterdam!
and you dont want anything to leak past when your under
full boost!...
and get it tuned before yah romp on it!
im still using the stock 98 heads and im gettin right around
370 hp 385trq on the dyno at 5 psi.. one slight problem im having is the lack
of 93 octane out here ! my car was tuned on 91.
I didnt dyno my car at it stock level but I heard a 98 a4 puts out around
280hp so i think i gained 80-90 hp through my 3500 stall. I have 60k on the
odometer now
