Sts Question
Old Jan 5, 2006 | 03:44 PM
JD_Z28's Avatar
Default Sts Question
I have everything hooked up on the kit but the exhaust pipe to the turbo pipe, I want to drive the vehicle to an exhaust shop, will it be ok to drive it this way. the turbo pipe is laying inside the exhaust pipe.
Old Jan 5, 2006 | 05:57 PM
trtturbo's Avatar
it will probably blow it out. you need to clamp it.
Make sure when you get to the exhaust shop, you put the turbo as high as you can before welding.
Old Jan 5, 2006 | 06:18 PM
WideOpenThrottle's Avatar
I agree that you will most likely blow it out. If you do clamp make sure you don't clamp to hard to where you bend the pipe to much or you will not be able to rotate it.
Old Jan 6, 2006 | 08:32 AM
Devil's Due's Avatar
Clamp it together just don't go WOT on the way to the shop or you will be reinstalling it on the side of the road.
Old Jan 6, 2006 | 09:02 AM
98Ztwentyeight's Avatar
Default mounting
I saw a pic where a guy used a header type flange on his!
I thought that was kinda cool!
incase yah ever had to take the gas tank down
to change your fuel pump and with this kit your gonna be
changing your fuel pump..
Old Jan 6, 2006 | 10:15 AM
Wolfee's Avatar
That might have been mine, it is all custom and while I was at it I just put a 3" header flange on both sides so it would come apart very easy if I ever needed to.
Wolfee
