Help with piping
Old Jan 6, 2006 | 09:41 PM
80superbu's Avatar
Default Help with piping
I'm going to be using a Gt42 turbo in my 80 Malibu. there are no kits for this (not that I would buy a kit) Is there any place that can give me some guidance as to the size of downpipe and exhaust to run with this setup? Will be using the 5.3 manifolds
Old Jan 6, 2006 | 10:27 PM
y2khawk's Avatar
what size turbine housing are you using?
the T6 flanged hot side is setup for a 5" DP
the T4 hot side and appropriate v-band flange can use a 4" or 3.5"
Honestly, run the largest that will fit. You'll make more power and it should spool easier
Old Jan 6, 2006 | 10:35 PM
80superbu's Avatar
This is the one:
Garrett gt42. 94mm w/ 70mm inducer. T4 flange 1.01 A/R
Old Jan 7, 2006 | 12:30 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
That's a 4" downpipe outlet. Run the 4" if you can fit it.
Jose
Old Jan 7, 2006 | 07:26 PM
BLWN1's Avatar
Have you tried the 5.3 mani's on yet?
Old Jan 7, 2006 | 08:23 PM
80superbu's Avatar
I have someone that I will be getting a set from. Just waiting on some pics right now. I just now got the motor out of the Z28. I want to swap out the cam, springs, intake and a few other things before I get it in the Malibu. Just trying to get the turbo stuff squared away
Old Jan 7, 2006 | 08:37 PM
BLWN1's Avatar
A set of 5.3 manifolds or custom headers? I have a 5.3 motor going in my bu, and the mani's are on it, just curious if they clear everything. Keep me posted on your progress. Did you decide what to do about wiring? What are you doing for an intake? I need a comlete intake....
Old Jan 7, 2006 | 08:42 PM
80superbu's Avatar
I have a FAST intake and Nick Williams TB. I'm going to use the factory LS1 wiring harness and computer...that's my plan.
There should be tons of room in the BU for everything. Custom headers?? Not me, I can't afford that stuff. I'm doing the poor mans exhaust ....cause I spent my money on everything else
Old Feb 18, 2006 | 03:21 PM
BLWN1's Avatar
Any updates? What engine accessories are you using?
Old Feb 18, 2006 | 03:33 PM
80superbu's Avatar
No updates yet. I'll have to wait 6 weeks until I get back before I can do anything else
